Somfy zdmi zwave
Has anyone integrated a Somfy zwave ZDMI unit into their Hubitat? I see that the only device listed for somfy is a button controller (?). Any thoughts on how to integrate a ZDMI?
Thank you
If you already have the ability to control your awning (or blinds/curtains) with an RF remote control the Bond Bridge works great to control Somfy motors. Sorry, I don't have experience with ZDMI, but I can confirm that this works perfectly. https://bondhome.io And there is a built in integration for it.
I already have the ZDMI hooked up to my Vera system, which I am transitioning from to Hubitat. Need to stay with the zwave approach.
Thank you
Fair enough. Hope someone can help. It's definitely not on the list of supported devices, and nothing is returned when you do a search here in the community. But, if anyone has a clue, they are here in https://community.hubitat.com/
Welcome to Hubitat!
Finally set it up as an on/off switch. Off to close shade and on to open shade. Works fine , except no ability to stop half way.
I also have a couple of the ZDMI interfaces and am coming from Vera3 UI5. I have mine set up as a Generic Z-Wave Shade device, but still no shade controls in the Hubitat app (except on Dashboard) and no stop command. Early z-wave shade controllers that treated shades like a dimmable light used to be that stop was achieved by canceling the scene. My problem is that my direction is reversed, and I'd think at this point anybody writing code would implement and reverse direction option for all shade and drapes. I am disappointed Hubitat doesn't have that, or maybe that's what the "Start Position Chage" command means, but it doesn't do anything. Not very impressed so far coming from an old Vera that just worked well.
