I am having an issue that just popped up today. Some things are unresponsive, yet others work.
For instance, on the Settings screen, I can view the Hub Details, and everything else, but the Reboot Hub, and Shutdown Hub do not respond.
I am trying to install Noonlight monitoring. I get to the point where I need to enter the secret code. When I do, and click Next, nothing happens.
On my Dashboard, I can pull up the HSM menu, select arm home or arm away, and nothing happens. If I close the menu, and select it again, the log does reflect the changes that I just tried to make.
The dashboard does not reflect the current state. For instance, I just armed HSM, and opened up a door. The dashboard showed HSM disarmed, and showed the door closed. However, the alarm did sound. I clicked the HSM tile, and clicked on cancel all alerts, and the alarm ceased.
I have tried re-booting the hub, and it did not help.
