Background: I have a single relay on a D1 Mini flashed with Tasmota, discovered as a device in HE, that I have embedded in my Keurig coffee maker. The Keurig has a momentary On/Off switch using 5V circuit on the rear of the unit, which I paralleled with my relay. To turn the coffee maker ON or OFF, I can toggle the relay: On / Delay 1 second / Off. I have a simple rule to turn the relay OFF after 1 second delay any time it is turned ON.
Problem: I want to create a Rule to turn the coffee maker OFF after 10 minutes any time it is turned ON, like this.
If relay turns ON:
- Delay 1 second
- Turn relay OFF
- Delay 10 minutes
- Turn relay ON
- Delay 1 second
- Turn relay OFF
As you can see the above will go into an infinite loop, I've tried Cancel Rule Timer -> This Rule, after the "Turn relay ON" above (and before), among other things. I can't seem to find the secret sauce for this Rule to not call itself when it turns the relay on. Any help is greatly appreciated!
