SOLVED: RM4 Syntax Display Error
Hi Bruce (@bravenel )
I believe there is a syntax error in RM in how conditions are displayed...
When creating a Simple Conditional Action using HSM Status, it is displayed correct.
When creating a full-on IF (conditions) THEN the display "error" appears; see screenshot
Instead of reading is (like the simple conditional), it reads becomes
Interestingly, when creating it, it initially reads correct...
I strongly suspect this is only a cosmetic display issue as I haven't tested it at all yet. Grammatically is just reads strange! The use of AND or OR has no impact on readability.
J
Yes, this has been reported before, and is indeed a ui bug. It's been fixed now, and will be in the next release.
