So I wanted to edit a rule in RM. The rule was basic.
If Everyone is not present AND time is between 6M and 11PM
Set mode to Away-Night.
I went in to edit the rule which went fine but when I opened the rule again I see this. It did this to 3 of my rules now. I am affraid to open up anymore rules.
Just happened to me.
I had modified this rule today by using a scene instead of individual devices.
It's changed from a rule to a schedule.
It used to have times, lux, motion. All gone.
Will this bring our rules back or do we need to re-write the corrupted ones.
I'm having to use my finger to press light switches. Whatever next..........
No, they are ganked. All the fix does is stop the destruction. Don't hit Done in any rules with times as conditions in the meantime. Fix coming quite soon....
Hi Bruce.
Just to let you know that I downloaded the hotfix.
I have re-written the 4 rules that I changed and they now save OK and keep their configuration.
I've also opened and click on 'Done' for my similar rules and they do not change now.
(You probably knew this already though).
Thanks for the quick response.
Excellent service once again.
