I can't tell if this is a bug or I'm just using it wrong, but I'm trying to set a dimmer to different brightnesses based on Time of Day when motion is detected. I've attached my configuration below and also a screenshot of the logs which state that there is some sort of Night condition preventing the light from turning on. Does anyone know what it might be referring to?
Had you fiddled around with the app before you decided what you wanted to do? I wonder if in the options for activate you have selected not turn on in night mode. Then you turned off the option but it's still there somewhere. If that's true it's a bug and needs to be corrected but let's confirm that before we get the guys in.
I'm assuming you're modes change depending on this?
I would try deleting the rule and creating it again, sometimes you activated a function you don't need anymore and the app doesn't properly ignore it.
@BorrisTheCat I didn't have any of the Options for Activate enabled, but it is possible I fiddled with them.
@MrPancake I recreated the rule and it works correctly now!
I suppose it's possible some option was cached, or maybe I had just missed something. Thanks for all the help!
