Upgraded from ..120 to the new firmware. Left the house after hub said that it was rebooting came back 9 hours hub was still rebooting. Unplugged the hub waited a couple of minutes hub has not come back online.Light on hub changes from blue to green but it does not connect to the network.
If itβs green but you canβt load the UI, it may have switched IP addresses. Could try http://hubitat.local or http://find.hubitat.com
Tried both. Hub has a green light but it's not connecting to the network.
Looks to be up and running in the support tool, see PM.
After a couple of reboots and not having any luck I moved the hub to a different part of the house and connected it to another network switch and that did the trick. I use google mesh routers and for some reason, the one it was connected to hardwired it wasn't seeing the hub but as soon as I put it somewhere else it started working again.
Might wanna run a z-wave repair so your devices can find new routes based on where the hub is now located.
Moved it back to it's original place without problem. Most of my system is zigbee with the exception of my switches that are zwave (Zooz).
Thank you didn't think about that.
Do you have a vlan running?
No
Strange indeed. It seems almost have it wasn't getting an address from your DHCP server but @gopher.ny could see it. I was thinking there may be something going on in that direction. Regardless, glad everything is good!
