I've been messing w/ the Safety Monitor for a few days now, but for some reason I cannot get it to do anything. I've configured several things and tried many different ways, but it will simply never send out an alert (either through SMS or Pushover), will not turn/blink lights that I setup, nor will it play any sounds on my Google Home Speakers either.
I also manually armed and when I open any of my contact sensors, or poor water on my leak sensors, nothing happens.
I already did completely uninstall the App too and re-set everything up as I found a thread here that said to do that, but unfortunately that didn't help either.
Try this, remove all your alerts except for turning on one light and try again. Make things a little simpler to see if the problem is HSM or the alerts you have set up.
Also, all of your sensors swap values in the edit device page?
You can also get a list of the HSM events by going to the settings page and then clicking on events.
Okay, i think your hub time might be off. Because if you just armed it now, it should have been at 11:53, not 10:53. You're only 2 hours different than me if you're in Mountain time.
After the system was armed, did you refresh the events page? Because if it's showing alert, but you don't have an alert event which is also not supposed to happen.
Most of the pages in HE do not auto-refresh on their own.
And you don't mention whether the light came on when you opened the contact sensor. Did the alert occur?
You didn't actually do what I asked and make the alert turn on only one light. I think your complex alerts are your problem because you are asking HSM to turn on a light and also flash that same light. That won't work.
Also, many devices don't support flash.
make sure the lights you are trying to flash are capable of flashing, i had a problem with a rule with flashing because the switch wasnt capable of it and the rule error-ed out and didnt run
It could be that one of your flash lights is throwing an error and blowing HSM out of the water. Whenever something doesn't work that you think should, open the Logs and watch what happens. Be on the lookout for ERROR there in red.
Ok so the Flashing thing was the issue I guess. Once I remove that it now seems to work. Going to slowly add things back in now. Thanks again everyone for their help.
