Does anyone using a CT100 Thermostat with Celsius degrees as the default have an alternative to Generic, Zwave Thermostat DH?? This handler does not work when using Celsius degrees.
If you use Hubitat (with the Generic DH) to set this thermostat what is actually is set and what Hubitat shows are more often 2 different things. For example, Hubitat shows the thermostat heating setpoint at 23C. The physical thermostat is also at 23C. Using Hubitat, set the heating set point to 22C. SURPRISE. The setpoint immediately jumps back to 23C. The physical thermostat however is set to 22C. To get Hubitat to show 22C you need to set the device down to 21.5C. Almost immediately, Hubitat changes the 21.5 up to 22C. The physical thermostat is set to 21.5C
While often a half to whole degree difference may not be that big a deal, it is really annoying and discerning that what setting I see within Hubitat and what is real are or may be different.
Looking for a working alternative DH for my CT100 zwave (none-plus) thermostat
