It seems that there are issues with the thermostat scheduler when I try to config it. Once I complete the procedure I just get this error:
2018-12-28 12:35:43.125 errorjava.lang.NullPointerException: Cannot get property 'value' on null object (mainPage
Anyone else seeing this ? I am on the 2.0.3 version.
Here are some screenshots of the error and the settings:
Same. @bravenel
App 1600 is the scheduler and device 755 is Thermostat - Virt
Ok. It seems to work as long as I don't set any schedules. Then I am able to open it and change settings.
Mine is mode-based, no schedules.
If it matters, the thermostat is in Cool mode but scheduler is sending a heating setpoint. I did not see a cooling setpoint sent.
Not sure if it matters. I have created several of these apps and it only works if I donΒ΄t have any modes and/or schedules (at least when creating a new one).
After the upgrade a previously working thermostat was broken. I could re-create it, but only without modes.
In my case it seems to be specific to setting a temp for Home mode. I deleted and recreated TS, was able to set the new instance to Mode based and enter setpoints for both Away and Night mode successfully. As soon as I try to set either a cool or heating temp for Home mode it gives me the error above. Could be because I'm currently in Home mode.
This bug has been identified. We will get out a hot fix release to correct it.
Back to working again with the hotfix. Thanks Bruce!
