[Solved] ELSE-IF not working for me
I have IF, ELSE-IF, ELSE-IF, ELSE-IF, ENDIF.
The IF is false so it should go on to the first ELSE-IF. This ELSE-IF is TRUE, but it gets skipped. I am very experienced with these kinds of conditionals and this makes no sense to me. Here is my log (read from the bottom up):
Action: // Set Energy Saver, if not already. (skipped)
Action: ELSE-IF (Variable WH_Mode(High Demand) is ? 'Energy Saver'(T) AND Variable Upper(126.8) is >= WH_Normal_Temp(119)-3.5(T) [TRUE]) THEN (skipped)
Action: // Set High Demand, if not already (skipped)
Action: IF (Variable WH_Mode(High Demand) is ? 'High Demand'(F) AND ( ( Variable Rate_Of_Change(-0.02502) is > ROC_For_HD(1.99)(F) AND Variable PC1(113.6508) is < 90.0(F) ) OR Variable PC1(113.6508) is < 50.0(F) OR Variable PC2(113.8776) is <= 40.0(F) ) [FALSE]) THEN (skipping)
Could you do three things?
  1. Post a screenshot of your rule.
  2. Post a screenshot of the logs from when the rule runs. It is much easier to read a screenshot v/s cut and paste text.
  3. Please don't omit any intervening logs (as long as they are also generated by the rule). This is also avoided by using a screenshot.
From the little information you've posted, it is possible that your rule met an earlier conditional that was satisfied?
It wasn't that simple, but it was my mistake. My rule is 120 lines long, and I missed and extraneous IF that had no ENDIF. In other languages I have used, this would have been flagged as an error.
I will have to be more careful in the future. Thanks for your help.
FYI, Rule Machine is not a programming language.
