For time zone, change it in the UI then reboot the hub, should be ok after that. At least that's what I think I had to do initially. Unless the time zone is actually assigned incorrectly, that would be a support issue.
Support is not only stellar, but so are the people here. Throw your questions out here. Someone is always here to help you. I can be considered an expert on this because I'm ALWAYS bugging the community for answers and I'm never disappointed. Welcome to hubitat. Once your timezone issue gets fixed I'm sure you'll be unstoppable. Good luck. Sleep sometimes.
when i drag in the map, the coordinates are changing, i press update and nothing really happens. I change the time zone and units to celsius and press update again. I back out of the location settings and go back in and its all back to where it was before the changes.
I have migrated 12 device over from ST.
4 ikea outlets,
2 ST door contacts,
1 ST motion,
1 ST outlet,
1 Xiaomi leak sensor (NEW)
3 inovelli zwave switches
All pairing went great other than the inovelli took a couple of exclusions from ST to get paired with HE, but it was painless.
I noticed the ST battery powered devices and ikea outlets paired quicker and more reliably than they ever did with ST.
Got my Fire HD10 mounted (Bob Strenger Mount)and powered on sunday. Rooted it, installed fully kiosk, dakboard and sharptools. ( I love sharptools!)
Now just starting to play with rules and finish migrating over the next week or so.
Everything went smoothly, zigbee and zwave discovered great.
Sharptools is aweome if you dont mind a bit of cloud lag. really hope they can somehow bake the dashboard into HE. Then HE team could worry about other things.
Now I have 8 more inovelli switches to unbox and install and some xiaomi stuff on its way from aliexpress/gearbest
Thanks to all those that helped me through the pretty much painless process.
