So a timeout doesn't change %device% anymore?
Did I miss something? I have a few rules where I look at the value of %device% after a wait to determine if the expression timed out. I just noticed one of my rules was not working so I made a simple test rule and %device% is null after an expression timeouts. See below.
Isn't this because the rule wasn't actually triggered by a device? :thinking:
I assume you just hit the run actions button.
Give it a whirl with a device to trigger your test rule and see if it gets written into the variable.
device should get set to "timeout" with or without a triggering device as long as the wait timed out, which is the issue here -- not whether it's set to the name of the triggering device, which indeed does require a "real" trigger.
This was reported on 2.3.2 a while back and I'm not sure it was ever addressed:
Tagging @bravenel to take a look, assuming this wasn't an intentional change or that there isn't a "new" way to do this.
You can tell I don't use RM anymore............ :slight_smile:
This baby probably got thrown out by mistake. I will look into it.
Found this problem. Fix in next release.
Thank you! This problem forced me to roll back!
I thought I had seen something about it, but I hadn't noticed any issues, so I never paid much attention to it. I know I use the technique in a few places, but I can't really remember where they all are. So hopefully the fix will be out soon, so I don't have to roll back.
Fixed in latest. 2.3.2.139
Yep that did it.
Updated and tested, confirmed. Thank you @bravenel
