Ok, something strange: I have had a SonOff Temperature sensor ( SNZB-02 ) running just fine for more than a year. Last week the zigbee connection seemt to be broken, as the device was not reporting temperature value's anymore. I tried to re-pair the sensor. It found the sensor as an existing sensor, and all seemed fine, but no actual value's came from the sensor. I tried pairing it again a few times, even with the keys in the clear option, but every time the same issue.
Thinking the sensor could be bust, i ordered a new one, the SonOff SNZB-02P. ( new model, zigbee 3.0 ) When it arived, I tried to pair it on the same location as the old sensor, but no luck.
"device found, initializing.." and there it stops.
next tried to do the same but holding the sensor right next to the C8 hub, but again the same message.
Tried both the "keys in the clear" & "avoid zigbee 3.0 repeater" options, but everytime the same issue.
Net I tried to pair a spare aquara temperature sensor on the same location als the old SonOff sensor, and it paired strait away, and works like a charm.
Any suggestions what might be causing this?
All my other existing SonOff sensors ( contact) seem to be running just fine.
