Hi everyone,
I was hoping the SMC Door Sensor SMCDW02-Z would work by default as a generic device with the Hubitat. Apparently not. The hub finds the device as a SmartSense Multi V1, but the status as a tile is always unknown. Does anyone have any suggestions?
Thanks!
isaac.kehle:
SMCDW02-Z
Did you change the detected driver to "Generic ZWave Zigbee Contact Sensor" and click Save Device?
aaiyar
March 10, 2020, 2:17am
3
Generic zigbee contact sensor
You could be right!! Although Google found schizophrenic listings:
Edited to be Zigbee.
Yes, I did try Generic Zigbee Contact Sensor
with no luck.
Also tried the same with no temp
After more looking, there are comments on some of the Amazon links saying they do not work with SmartThings, proprietary code, etc.
Unfortunately I did not find the Amazon link until -after- I hit buy on eBay...
alexd51
October 21, 2020, 12:06pm
8
You just saved me some money. Was about to buy a lit if used ones.
I believe they are proprietory for Xfinity / Cox systems only. I have tried as well.
system
Closed
September 22, 2022, 5:34pm
10
