@waynespringer79. Looks like it changed. Now I know it is able to communicate with the HUB
@waynespringer79 Well I just looked at the Water Sensor... Battery at 0% WHAT?
Dunno, although I do have several smart things motion sensors that report either 0 or 1% battery routinely. But they report activity regularly so until they don't I myself don't worry about battery levels.
@waynespringer79 Ya it just bounced back up to 99%
I have the same problem here after going through two Samsung devices. It's stuck on wet. Is there a better water sensor in the market? I convinced it is a Samsung issue after going through two with the same issue..
Eventually I got this thing working. Been working ever since... I think.
And how did you do that?
It was a while ago.
I think I ended up taking the top of an using a hair dryer and letting it sit for a couple days.
Something like that.
They did issue a firmware update a few weeks ago if you have, or know someone who has, a SmartThings hub to update it. I’m not sure of what the update was supposed to fix. I have 2 of these that have saved me from flooding due to my kids putting too much detergent in the washer a couple times now and they are still working perfectly, so I have been hesitant to try updating them.
I can NEVER resist a good firmware flashing session, so I paired my 2 samsung moisture sensors back to ST and the firmware updated from 00000011 to 00000014. The batteries took about an 8% life hit due to the update. It's been 3 days and both sensors are working fine, along with a V4 multi motion sensor I upgraded. I tried to upgrade my V5 multi motions but there wasn't an update available.
Not sure if I gained anything, but it was fun and didn't break anything-yet-ALTHOUGH 1 of the sensors, after being paired back, post upgrade, to HE and included in HSM flood alerts and actively reporting temperature every 6 mins, did not set off HSM when I wet it, I had to re-discover all over again, and now it's working with reporting water.
In the past with ST, i had their firmware upgrades trash 2 sensors, so there's that.
If it ain't broke don't fix it-ain't for me!
There’s also an update for the button controller
Does Hubitat support updating the firmware on these devices? The process to unpair from HE to ST then back to HE is a total life suck especially if you have many rules setup.
Does Samsung make the firmware publicly available?
Good question. If no, then my question is void I guess...
Not really. Hubitat needs a zigbee firmware update process like @bcopeland’s zwave firmware updater. But it still relies on firmware being available.
I have seen Sylvania/Ledvance post links to firmware updates, but that’s it. I haven’t tried asking, but not liking my chances for getting firmware from Samsung. Probably be a cold day in a hot place before they give it up.
