SmartThings Water Leak Sensor
Temperature is set at the hub level via Settings / Location and Modes. Drop down at the bottom of the Location settings to choose Temp Scale, Time Format, etc.
Regarding why itโ€™s not reporting wet, unsure as mine have been working great. You may try to reset the device and put hub in pairing mode and pair again. The hub will realize it was previously paired. Then test again.
Thanks, that helped!
