Hi guys. I have a smartthings outlet which doesn't appear to be reporting it's power correctly. It seems to be reporting approximately 10% or the true energy consumption. My driver is "Generic ZigBee Outlet" it has been working fine until Circa 4 weeks ago.
There are several different models of SmartThings outlets. Can you copy and paste your particular device information from the device web page 'Data' section?
I see something strange here - the model and the manufacturer are missing from the Data section ... I don't know whether the "Generic ZigBee Outlet" uses this data or not, but this may be a problem.
Try pairing the outlets again to HE (without removing the device!), all your automations and dashboards will be kept. Hopefully pairing it again will solve the power reporting issue.
Fantastic @kkossev. Really appreciate your help. I had to delete and re-add the device but it worked perfectly. Not sure why this occured but oddly it happened to 2 of my 3 smartthings outlets
