Smartthings app with Hubitat hub
I have a Hubitat hub, and I use the Hubitat app. However, I also have a few Samsung appliances, so my wife uses the Smartthings app. Is there a way that she can use her Smartthings app to control the devices that are connected to our Hubitat hub. We do not have a Smartthings hub, and i have no desire to get one. Thank you in advance.
Hubithings replica will do this. I use it to share a Samsung TV (of all things) back through my smartthings account to our brilliant wall control. My ST hub went in the trash a long time ago.
Thank you very much. It worked for everything but my thermostats. When you go to add the thermostat, you have to pick a category under the Smartthings virtual device type. There is no thermostat type, so I tried to do it under Virtual Custom Device type. It will then add it, but since its not thermostat type, there is no way to change temperature settings and etc.
What kind of thermostat? Chances are it’s a cloud based integration that can be added to smartthings without a hub.
Its a Radio Thermostat of America CT101 zwave thermostat. I originally bought it when i got IRIS several years ago, and it works great on Hubitat.
Unfortunately, that is certainly not a cloud based integration.
Either way, thank you for responding. Everything else is working good, so thank you for the info
