I want to put a large heavy cabinet in front of the first receptacle in a circuit which, by virtue of it's position in series, is the GFCI. It will be very hard to reset if ever triggers so I wonder, are there any smart-reset GFCIs? I see smart alert GFCIs and that's close!
Can you put that circuit on a GF (or combo AF/GF) breaker instead?
Very good idea, do they make type RC (2-pole zinsco) GF breakers? I’ve never seen one, unfortunately.
Sorry, I don't have any experince with that particular breaker series -- if google doesn't turn anything up, then perhaps there aren't any compatible.
Does that outlet need to be GF, or can the next (more accessible) outlet in the circuit take over that role for things downstream?
Maybe move the GFI outlet farther up the chain where it is accessible and put a regular outlet behind the cabinet. Assume since you are blocking it, it won’t be used anyway.
Unfortunately this location is the initial drop from the panel (nothing further upstream) and there are 5 more downstream that I care about. ![]()
I use several of these connected to a smart outlet for my outside holiday lighting.
If moisture triggers them, a simple shut off via the smart outlet and power back on resets them...
From your description, the location of that outlet doesn’t appear to need a GFCI, although downstream outlets in that circuit may need to be GFCI-protected. If that’s the case, why not make that outlet a regular outlet, and make the next downstream outlet into a GFCI?
If you have a Zinsco panel, you need to update it before you lose the house from a fire.
Zinsco breakers are extremely dangerous, they don't trip when overloaded. I recall the panels have busbar corrosion problems due to being aluminum as well.
Please have this checked if you have one of these panels, or these breakers.
Exactly and similar to what I was trying to suggest above. Let me give an example of my kitchen. Line from panel goes to an outlet on a wall along a staircase. From there it goes to an outlet along kitchen counter and continues to many other outlets along counter and the island. GFI is installed on the second outlet along counter because those outlets annd island are required by code to have GFI but that first outlet isn’t. Now I am speaking of code from several years ago so unsure in recent years.
Especially the double pole breakers. Same with FPE panels.
For the safety reason GFCI absolutely cannot be turned on remotely.
Another good option could be to use GFCI Circuit Braker in the Electric Panel on the circuit in question.
Yeah, that's what I assumed to be the case but thought I'd ask anyway!
