Am looking for a Smart Plug with a manual switch. Application: hair curler left plugged in, using geofencing to turn it off. Don't want to turn it back on with geofencing, don't want to use phone to turn it back on, just want to push a manual button on the Smart Plug.
I’m partial to these for that purpose.
They act as a zigbee repeater and the power button is prominent.
SYLVANIA SMART + ZigBee Indoor Smart Plug, Works with SmartThings, Wink, and Amazon Echo Plus, Hub Needed for Amazon Alexa and the Google Assistant https://www.amazon.com/dp/B01M6UM8QD/ref=cm_sw_r_cp_api_i_dBo5EbZ30C1DS
Every smart plug I've tried so far has a push button for manual control:
Hue
SmartThings
Aeotec
Here's the exception:
No push button. The pinhole that you see on top is for a factory reset.
Mine is an EVA LOGIK. Turns out that the button on the top does turn it on and off. For some time that button was not working but now it does. So as it turns out there is no issue.
The TP-Link smart plugs also have a switch. (community developed integration).
