Fairly manual process for us. Grind the beans in an electric burr grinder, boil the water and pour it over the grounds.
Only automation is “Hey Google, fill the Kettle”. I kind of like leaving some manual efforts in my life to remind me I’m not lazy, I just enjoy automations. That said, if we ever went full auto in that respect, the all-one units that grind with a conical grinder, then brew with proper wait times to allow the grounds to “bloom” and expel Co2 before continuing, are what interest me the most.
I'm at the point where I don't trust any startup with a cloud based smart device. I've been bitten too many times where I buy an expensive device like a $500 coffee maker only to have them go out of business in a year (because seriously --- how big is the market for $500 coffee makers???) and poof cloud server goes down and the "smarts" are now "dumb."
I really want a smart coffee maker too but I think the best solution is an old drip coffee pot and a smart switch triggered by your motion sensor.
Thanks for your input guys. I think I will just go with another non smart coffee maker that has a timer for this go round. Hopefully next time I need to shop for one, there will be more smart options available.
I recently set up automation with a portable zigbee button (Coffee Pot Ready), a virtual switch (Coffee Brewing Activated), a zigbee plug (provide power to the pot), and an electric percolator pot.
When the button is single clicked, I marked the pot as Ready (switch is on).
When an Alexa routing is triggered by the morning schedule, the Activated switch is set on.
When both switches are enabled, then a rule turns on the plug.
The Ready switch is turned off after a minute through the rule engine.
The Activate switch auto shuts off after 10 seconds (in the switch properties).
A simple rule was created to auto turn off the plug after 2 hours of cooking the finished coffee.
Also I used IFTTT to create rules to turn on both switches (start brewing instantly). And to simply mark the pot as ready.
If this is of interest, I can take some screen shots. I figure this could pretty easily be a bundle.
I use a Zigbee plug to a dumb coffee maker. No timer on the pot itself. When I get the coffee ready I turn on the switch on the pot itself. Then normally at 5:45 am the plug starts the brewing. If I need a different time I can turn it on via a dashboard link. In either case it turns off after 2 hours. I have a condition if we are not home the plug will not come on just in case we left the pot switch on. I also have a switch on a dashboard to disable the auto start, kinda like you do with ready but in reverse.
Nice thing about this compared to a pot with it's own timer, if the power goes out I don't have to reset the clock.
I really want a non keurig machine that I can tie into my water line so I dont have to keep refilling with water and I can pull of my filtered water line.
The K2500 has an optional plumbing kit so you don't have to fill the water tank. We had a larger model at our office and our facilities put a in line 6 month water filter on the plumbing kit. We had a total of 96 of them deployed company wide. They were very reliable and easy to maintain.
We will probably get the Atomi when our Cuisnart grind and brew goes. I mean I'll just set a notifier for it on a virtual switch. Beyond that there isn't really a need for it to be smart lol
