Nothing jumps out as being horrible. A lot of those shade controllers have a lot of route changes which is a little concerning (could be leading to your issues, or an effect of other issues).
So I see 0x33 recirculating pump, sounds like maybe that is a plug, ZEN15 possibly?
And then also 0x40 Is the ZEN25.
For the ZEN25 it is known to cause issues when the reporting is left at defaults. If you are not using the info I would set all the reporting intervals / thresholds very high to get minimal reports. There is also a newer parameter you can set to totally shut off the reporting but it is not visible with the system driver. Parameter 18: https://www.support.getzooz.com/kb/article/1154-zen25-double-plug-advanced-settings/
If the other is a ZEN15 you can use this driver to see all the settings, save advise as above for the ZEN25 applies: [DRIVER] Zooz Smart Plugs Advanced (ZEN04 / ZEN05 / ZEN14 / ZEN15)
