Slow to no response on ZooZ zen35 button presses led me to a ZWave rabbit hole and I think it's messed up
I have a C7 running 2.5.0.143. I recently transferred everything over to a new C8 pro and then wiped this C7 to dedicate to my home theater setup. (I know I can use the C8 but was trying to keep it simple for my husband to manage)… After doing all the required setup I successfully added 6 devices: 3 Zooz Zen35 scene controllers, 1 zooz zen37 remote and 2 zooz Zen56 RGBW dimmers. This is all that is on the hub.
I created 3 simple automations: 1 scene that turns Can lights, Sconces and LED strips to full bright, 1 rule machine that turns Cans to dim, Sconces to dim, LED strips to full bright blue, 1 Room Lighting that sets everything to dim. These took a while to get working properly - but they were working from the app interface and the button push I assigned on the scene controllers. Then today - nothing is working right. The delay was a solid 30 seconds and then only half the lights did what they were supposed to. No matter which button I triggered, nothing is working right. Logs are showing delays and time outs.
I started diving in to the support threads to find out what might be causing a delay and did all of the things suggested. One thread I came across said to make sure my zwave version is the latest. It wasn’t - it was 7.14. I followed the steps to update using the http://192.168.1.2/hub/advanced/installZipgateway718 but once this completed and I rebooted, my version looks like this:
VersionReport(zWaveLibraryType:7, zWaveProtocolVersion:7, zWaveProtocolSubVersion:14, firmware0Version:7, firmware0SubVersion:14, hardwareVersion:1, firmwareTargets:1, targetVersions:[[target:1, version:7, subVersion:18]])
The threads said that wasn’t good - that all the subversions should show 18 not just the target version section… I’ve shutdown, rebooted, rebooted with a database rebuild, but this doesn’t really help anything.
So my question is - is this zWave version thing a problem and is it causing my delay issues with the lighting automation I am trying to do? If not, anything else I should look at to fix the response times?
@nicole.vollmer Did you ever resolve this? I have two Zen35 and experience the same with them being delayed to respond.
I update the firmware and still no luck.
No, I actually haven't solved it yet. I have all the settings as tuned as possible and sometimes it works fine, but if the switches haven't been used for a while or if I try too many different button pushes in a row, it really lags. I've kept my LEDs off (to eliminate the zen56 as a variable) and that improves some but not a lot.
I fed my logs and z wave log to Claude and he thinks I have an interference problem. I'm going to bring the hub into my theater room directly and see if that helps. If not, I'm going to try the C8 pro and if that still doesn't work, well at least the switches look pretty lol!
Is your C7 hub installed in a metal network cabinet? I'm seeing similar issues with my Zooz Zen35s. Interference was suggested as a possibility, but I haven't tested it outside the enclosure yet.
I'm skeptical that interference is the sole issue since my Leviton Z-Wave switches operate without problem. My main issue is lag when using multi-taps or button presses to trigger other devices/scenes, whereas the primary local switch response is usually fine.
I disabled all the multi tap functionality to eliminate the wait time in between presses, that helped but didn't fully solve. I think the routes are having trouble staying in place and are rebuilding due to timeouts or periods of non use. If I turn any of the lights off manually, I see the most delay when I use again. The C7 is not in a cabinet but is in my utility room next to a receiver and other devices. I have t moved the hub yet either to see if that helps. But it's working 'good enough' until I can terminate some wiring inside the room.
