Sliding door and screen/security Smart Lock Options
Hi every
I've decided to have another look around for smart locks for both sliding glass doors and security/bug screen doors. I just haven't been able to find any options and thought I might reach out to you guys to see if you have come up with anything.
Regards
Marko
Yale Assure locks work on Anderson doors, but not sure about other manufacturers
I've been looking for a screen door solution too. I haven't seen anything that would work right out of the box yet. Some sort of electric door striker and a Zigbee relay would do the trick. For me that's a big project.
Same boat here. Was thinking about doing it with a magnetic lock, but I didn't come yet to an elegant solution of failing secure on a day-to-day operation but failing safe when in an emergency. One idea I had is to set up a fail-safe one and to have it powered via UPS to implement fail-secure, with a cutoff cord to disconnect it from power after the UPS in case of emergency. So far an idea of a cord hanging in the middle of the great room didn't get much support from the wife, though.
Thanks for your ideas and thoughts. I might investigate the manufacturer that was mention
Also looking and didn't find anything yet.
Please keep us posted on whatever you find!
I too am very interested in this topic.
I had created one that works like a clicky-pen; momentary power ... pin out. Momentary power ... pin in. It worked, but I didn't think about an emergency situation where I'd want to very quickly disable it, so I never installed it, then someone busted into my car and stole it :D.
I came up with a concept of pulling the handle of the sliding door being the dislatch (again, similar to how those pens disengage when you pull the tab), but I never implemented it. Maybe I'll have at it again this winter.
Others have done the electromagnet thing; easy to implement, fails during a power outage though, but I don't think guarding against that is all that valuable anyways, unless power is SUPER unreliable at your house.
I wonder if something like this could be adapted such that a normal rotary actuator - like for a normal smart door look - could be used to activate it. It looks like it simply needs a 90 degree rotation to lock/unlock. Or failing that a stepper motor with a hubduino.
TOP KNORR Sliding Door Sliding Door Lock Modern Invisible Sliding Door Lock Zinc Alloy Hook Hidden Hook Hidden Door Lock
Tuya wifi lock with an option suitable for sliding doors. Not sure if we could get this working on HE using the recently developed Tuya integration found elsewhere on this forum. The trouble is, that would be dependent on the Cloud. Boo :face_vomiting:
Yoheen Wifi Tuya APP Remote Unlock Electronic Digital Smart Fingerprint Door Lock for Aluminium Sliding Glass Wooden Door
I just paid about $30k for some huge sliding door projects on my house, with the promise of them being able to use my standard fingerprint deadbolts mounted up at the top, with the bolt going into the trim to lock it (with some sort of reinforcement.)
Of course, they install everything, and tell me that they don't want to do that. Say I really need to use a sliding door lock. Seems there's jack-sh out there on this front. I found the Tuya Wifi sliding door lock linked above, but I guess you cannot install tasmota or get local integration in any way?
This one is interesting as well:
ah dangit, this is also Tuya.
I did email the shop to see if they knew whether this was ESP-based, or Realtek-based. If it's ESP, then I can flash the tasmota firmware. Not sure what will happen to the lock after that, though.
There's also a mock-cloud solution, but seems abandoned. I'm a bit lost in the Hubitat threads on the matter -- as to whether or not items like this can be set up to use a local solution.
