Skypane — self-hosted wall-panel dashboard for Hubitat (work in progress, live demo, feedback wanted)
Hi all,
I've been building a wall-panel dashboard for our Hubitat house, and it's far enough along that I'd like other people to try it and tell me what they think. It's called Skypane. It's self-hosted: it runs in a small Docker container only option currently (I run it on Unraid), and any tablet or screen shows it in a browser or a kiosk app.
It's a work in progress. Things change often and some parts are still rough. That's why I'm posting now: I'd rather hear what's confusing or missing before it's "done".
Try the demo
https://skypane.huskyserver.us — sign in with demo / Skypane-Demo.
  • It's a pretend house. Nothing you do reaches a real home, so switch anything, build layouts, break things.
  • You get your own private sandbox. Nobody else sees your changes.
  • Up to 10 people can use it at once. After 15 minutes without doing anything you're signed out, so the next person gets a turn.
  • The Feedback tab on the right edge of every demo page sends me a note straight from the page you're on.
  • Some parts are switched off in the demo: the Hubitat connection, MQTT, real cameras, calendar links, accounts and guest Wi-Fi. Camera pictures, calendars and weather places are samples.
It isn't up for download yet — the demo is the way to try it for now.
What it does today
Built from your Hubitat. It connects through Maker API and builds the panels from your own rooms and devices. You review and adjust in a web page (the "Manager"): what each device is, which room it's in, which devices a panel may never switch. No YAML, no code. A change on the hub shows up without touching the tablet.
Panels. A Home page and a page for every room: lights (dim, white tones, colour), fans, outlets, shades, appliances, sensors and that room's cameras. Several panels (one per tablet), each with its own rooms, layout, theme and alerts, all set up from the one Manager.
Alerts from Hubitat. Your rules (Rule Machine, webCoRE) send alerts to the panels through a small Hubitat driver, the Skypane Notifier: a leak, smoke, the freezer, a garage left open. Each has a level from 1 to 5 and the panels it goes to. Levels 1–3 are a line on Home; levels 4 and 5 fill the screen and sound until dismissed, with the panel PIN. Every dismissal goes back to Hubitat, so a rule can turn the sirens off. The panels can also speak.
A layout builder. Drag-and-drop in the Manager, with the real panel live in the middle: drag cards in, move and resize them, undo and redo. About 44 card types (devices, values, thermostats, who's home, locks, doors & windows, weather, calendar, clock, cameras, scenes, modes, the alarm, timers, energy, batteries, shared lists and notes, a photo frame) and blank cards you fill with your own pieces. Every card has its own style and its own tap / double tap / press-and-hold actions. The thermostat card has 12 looks — halo ring, arc with a knob, slider, thermometer, glass orb, twin rings and more — and every look works the thermostat the same way.
Cameras. UniFi Protect cameras show up by themselves; any other RTSP camera works through the built-in go2rtc. Live grids, full screen, camera views, a room's own cameras, and "show the door cameras when the doorbell rings". (The demo shows still pictures, not live video.)
Looks. An animated sky with sun, moon and clouds and live weather effects (rain, snow, fog, storms), color themes, built-in backgrounds or your own pictures, icon sets and your own icons.
Also: calendars from any iCal link (read only), a guest Wi-Fi QR card, a child lock, the panel PIN for anything risky (unlocking, the garage, the alarm), Manager accounts with their own permissions, and a health check that tells you (and Hubitat) when something stops working.
It fits with my other projects
  • Switchboard — a Hubitat app for announcements, notifications and sirens. Also still in development: GitHub - almulder/Switchboard: Switchboard for Hubitat · GitHub
  • Sonos Panel — a touch panel for people with Sonos systems. A Skypane panel's Music button can open it.
  • Cameras — the UniFi Protect / RTSP (go2rtc) camera support is shared with the panels.
What I'd love to hear
  1. Your wall: which tablet or screen (model, size, landscape or portrait) and which kiosk app? Does the demo look right at that size?
  2. Where did you get stuck? Anything in the Manager or the layout builder that didn't make sense on the first try.
  3. What's missing for your house? Devices that need their own card (energy, EV charging, irrigation, pool, robot vacuum, 3D printer…) — please name the brand and the Hubitat driver or app.
  4. Alerts: would you send alerts from Rule Machine or webCoRE with levels 1–5? What would you send, and to which panels?
  5. Looks: which thermostat look, theme and background would you actually put on your wall — and which would you never use?
  6. Running it: would you run it on Unraid, plain Docker, a Raspberry Pi or something else?
Reply here or use the Feedback tab in the demo. Screenshots of your current dashboard are welcome too — the good and the bad.
Thanks for trying it!
Update:
Looking for real-world testers: Skypane, a self-hosted wall-panel dashboard for Hubitat
I’ve been building Skypane, a wall-panel dashboard for Hubitat that runs on your own server in Docker. It’s now at the point where it needs real houses, not just mine.
What it is
  • Wall-panel pages for tablets: Home layouts, rooms, cameras, alarm keypad, thermostat, calendars, weather, timers, lists, guest Wi-Fi QR card.
  • A web Manager to set it all up, on a computer or your phone. It covers devices, panels, a drag-and-drop layout builder, cameras, pictures, accounts with several admins, and a health timeline.
  • Alerts in 5 levels through a Hubitat driver. Life-safety alerts need the panel PIN to dismiss.
  • Guest mode can lock the panels or blur the calendar while guests stay.
  • It uses Hubitat’s Maker API and comes with its own MQTT broker. UniFi Protect / go2rtc cameras are optional.
Who I’m looking for
  • People running Hubitat with a Docker host (Unraid, Synology, a Pi, anything).
  • Ideally more than one wall panel (tablets of any brand). Multi-panel homes find the bugs a single panel never will.
  • People willing to use it day to day for at least a couple of weeks.
What I’m asking for
This isn’t a “try the demo and tell me it looks nice” request. I need people who will:
  • Run it on their real system, with their real devices, family and routines.
  • Report what actually happens: what broke, what confused you or your family, what was slow, and what you wished it did. Include steps and screenshots where you can.
  • Answer follow-up questions so I can fix things properly.
If you only want to look around, the demo is open to everyone: [demo link]. You don’t need to sign up for that.
What you should know
  • It’s a test release. Expect rough edges, and keep your existing dashboard handy.
  • It runs entirely on your own server. Your Hubitat token and passwords stay there.
  • Setup guide: [install link]. Help: [help link]. Code: [GitHub main link].
Interested? Reply here or message me with:
  1. how many panels you’d run, and which tablets;
  2. what you’d host it on;
  3. roughly how many Hubitat devices you have.
Thanks. Real feedback is what turns this from “works in my house” into something everyone can rely on.
Very impressive work so far, and I hope the community rallies to kick its tires!
Thanks, its been months of work to get it here. and have more to go. Been tracking down the security holes lately and plugging them and I think they should all be plugged now, might be a home network but somethign rouge could try and take control over it. I have lots to tweak and more testing then you can imagine. if I get people seriously interested and start providing feed back a time will come I would want people to test the real deal.
Looks good, but unfortunately I am unable to view it, coming from Iceland:
How does this compare to mDash? I've been using it and it's impressive and seems similar in its approach.
I need to get that fixed. As cloudflair is blocking non usa addresses.
mdash is mobile first design. This is a wall panel first design. I do have on the road map a phone version but have not decided how to implement as setting up hosting for remote access for phones becomes a monthly expense. And cost to put into app stores and cost to maintain them. This is why its only after i get this finished.
First phase was maybe just a webpage and you would setup tailscale or something to connect back home. But that only works for people who understand that setup.
when you have time try again and let me know if you can get in now.
She's all good now for access...
Is your plan to roll all of your projects into one Docker container? If so I'd love to run it on my Synology for testing.
Its currently running in a docker on my unraid, but setup would eb the same for you. I plane you make it so people can run it on any docker service they chouse, including raspberry pi.
Its not ready for live testing, I have lots to clean up and such. Also I have some things in the works for later but I have not announced them yet incase I cant get them to work.
Keep an eye on the Demo site as I will be updating it regularly with my updates / progression.
