Siri / Apple Home Dimming problems
Is there a resolution to this issue?
I too can execute Siri off/on commands (to Generic Z-wave dimmers and Zigbee Bulbs) via Apple HomeKit which update the Home app as well as the actual devices attached to Hubitat.
When I execute a Siri setLevel command to HomeKit (which updates the Home app, it doesn't update the Hubitat devices.
When I execute a setLevel command via the Home app, it does update the Hubitat device.
Any pointers to resolution appreciated.
I am having the same issue now.
Prior to a few days ago, I was able to issue siri dimmer% commands with no problem.
You replied to a topic from 6 years ago regarding a third party integration.
Are you using the built in integration or the Homebridge integration?
There are already two newer reports of similar issues:
If using the built in Homekit Integration, staff is looking at it and asked for a Hub ID from a user already:
@gopher.ny Do you need any other hubs with the issue to look at?
Thanks for the reply!
Yeah, I noticed this was an old thread, but hoping someone (like yourself) would respond!
I'm using the HomeKit Integration. Thanks for pointing me to the "HomeKit dimmer switches" thread. I did a search for "Siri" as that's the main problem for me, so that's why I didn't find the newer thread.
I'll chime-in there.
Thanks again.
