Siren 6 chime triggered by water sensor not repeating
Can someone please help me create the rule, basically when my yo-link sees a water leak to trigger chime 30 on the Aeotec siren 6. I have that working create, I can not figure out how to make it repeat indefinitely while water sensor is showing wet. It only does it once (26 chimes exactly) and no matter how I do the repeat rule it won’t repeat. As soon as sensor goes dry and wet it triggers again no problem.
Can you post a few of the scenarios that you've tried that were not working? I'm no pro at RM, Still learning myself but have learned a lot in the time I've been using it.
Jimmy
Having the same problem here. Aeotec Siren 6 will play any of its sounds once when triggered.
Using the Aeotec Siren 6 New driver, it is the one on the compatibility list.
Not the expected behavior.
