Hello,
Does Hubitat support Sinope/Sedna wifi water valve ?
On their site I could find info but only about Zwave/Zigbee support.
Apparently the Wifi valve supports Google/Amazon assistant.
I have aquara water sensors, I would like them to trigger valve … is that doable ?
Thank you
No, HE doesn't support the wifi valve. If you're looking for a good compatible water valve you should look at the compatibility list here...List of Compatible Devices - Hubitat Documentation
aaiyar
3
The zigbee version of that valve works with Hubitat.
