Sinope Load Controller Errors
I replaced an "Aeotec Heavy Duty Switch" with a Sinope Load Controller. No problems with pairing it and I'm using the built in "Sinope Load Controller" driver. Both debug and text logging are disabled. I'm seeing the following error every 15 minutes in the logs.
2023-11-13 07:30:06.056 AMerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: loadControllerRM3250ZB.checkState() is applicable for argument types: () values: [] (method checkState)
Any one have any thoughts?
You you have a scheduled job running from a user driver. Load the Device driver then click the delete all scheduled jobs command...
That did the trick, thanks
