@stephack After messing around, I have added a couple of lines of code to your Virtual Container and Virtual Momentary Switch that can be used as a simplified Sonos Station Manager. Using the parent/child relationship, I can trigger Sonos PlayTrack events based on one single parent attribute changing, and then create unlimited child devices without having to modify any code, apps, or other devices. Simply create a child device and set the Station uri inside that child device configuration. When the device is turned on momentarily, it changes the parent's uri to match the child's uri. An app then looks for a change to the parent apps uri only and acts upon it. I wonder if you or @Cobra might consider this method to add to your apps so that it is cleaner and can be used by the community.
Add to Virtual Container:
attribute "uri", "String" //INSIDE DEFINITION
Add to Virtual Momentary Switch:
input "trackuri", "String", title: "Station URI", defaultValue: false, displayDuringSetup: true, required: false //INSIDE PREFERENCES
parent.sendEvent(name: "uri", value: trackuri, isStateChange: true) //INSIDE THE PUSH() STATEMENT
A rule (wc rule currently, but want to convert to RM or other) is triggered by a change to parent.device.uri and then issues a command to sonos to playtrack "parent.device.uri".
I would appreciate your help or guidance getting this logic out of WC and into RM or another supported app. It is very simple and what I like is the speed at which i can create new stations versus other options.
