I am looking to set up a simple rule to heat a cat house. I have a heating pad in the cat house that i want to turn on (smart plug/switch). I want it to turn on if the temperature drops below 50 degrees and turn off if the temperature goes above 50 degrees. Do i have to make two separate rules? Can someone post what the rule would look like and how to set it up so it is one rule? Thank you.
