I have a question on Simple sprinklers. Hopefully someone knows the answer.
I use Simple Sprinklers to control 3 zen 16s I've set up as a 9 zone irrigation controller.
In the app there is an emergency shut off that i’m wondering if i can use as a rain delay…but i’m not certain if the emergency shut off only halts the schedule that may be running at the time…or if it will halt the schedule until the status of the switch selected is turned back off.
To explain ( or question ) further.
If i were to create a virtual switch and select this as the “emergency off” trigger.
I presume that if the sprinklers are running - then when i turn this switch on - it will turn off the active zone and halt the remaining zones from running.
Also presume that when i turn the virtual switch off that the next scheduled cycle will operate as normal.
My question is - if i leave that VS switch on - will it continue to halt the schedule until turned off…or if it only interrupts the current schedule when the emergency interrupt was triggered.
Reason i ask. If the emergency interrupt continues to halt the zone schedule..i can use it with IFTTT as a rain delay.
Setup.
Sprinklers are set to start at 6 am - stop at 60 AM
Irrigation Virtual Switch ( status is either on or off). In my case, the default would be off - unless i want a rain delay.
IFTT Applett . If rain forecasted for the next day - send a command to turn on the Irrigation Virtual Switch….at this point ( if the emergency shut off works as questioned above ), the zen would not run their next schedule until the Irrigation Virtual Switch was turned off
Simple Automation. Send an Off command to the Irrigation Virtual Switch 5 mins after the schedule was set to finish ( 635 AM) . that way the irrigation controller is now ready for the next schedule - the following day…unless rain is forecasted again and the process repeats.
So- anyone know how the emergency shut off on simple irrigation works?
Thanks in advance.
Mac
Update. I think i answered my own question by setting up a test. I set up 3 different schedules a few minutes apart. Turning on my virtual switch for the emergency shut off does interrupt the current schedule BUT the sprinklers will run on the next schedule - even if the virtual switch is still set to on status.
Dang it...was hoping for a simple rain delay solution.
will leave the post in the event someone has a different solution. I could put a smart plug in and just power down the 3 zen 16s but i know taking zwave devices off line is frowned upon
Mac
