I am using a Fibaro Roller Shutter 3 in kitchen and other areas.
I am attempting to make a Rule which will open the Roller Shutter in the morning at 7:45 AM to a level of about 80 ( the level to which it should open ).
I would like to know if the following Rule is correct or is there another way of setting this up?
I had tried that but i.e. only setting the level but nothing happens - the shutter remains closed
Perhaps, I may have to change the Rule for the Evening of the same shutter......I should set it to different level ( nearly a closed level ) and then change the level to 80......
I will try this and revert....
I finally solved this issue.
Instead of using Rule Machine, I used Simple Automation ( as I am very new to Hubitat and only just started setting up I was not aware of the feature ). With Simple Automation it works just the way I want..
