Two nights ago I created an automation for my Christmas lights using the SIMPLE LIGHTING app. They are supposed to go OFF at 10pm, but they have yet shut off at their scheduled time:
This is in the restriction section right? The simple lighting app only allows turning off and on between sunrise/sunset or vice versa or between set times oinly. The restrictions are not actions. The only way to do this is via rule machine.
I ended up doing an on action for my porch lights on sunset, then setting a separate off action at a specific time.
It does not seem that this is a complex scenario that should be programmed into the simple lighting as that is pretty basic. For now I will just leave it that way with two separate actions. Thanks for your suggestion.
