i have a rule that should be very simple, turn on lights 10 min after sunset and off 60 min before sunrise. it used to work and now it doesnt get triggered. here are the settings
what am i doing wrong ?
I see you have logging enabled which is a good thing. Are you able to share those logs with a screenshot taken from a tablet or a PC? (It would be difficult to read from the phone…)
I don’t notice anything wrong with the rules - have you tried pressing the “done” button? If so, have you also tried re-creating them?
In case this is a database corruption issue, you could restore one of your backups - the easiest way to do this, If you are on the latest platform version, is to go to settings -> reboot and you will see an option called “Rebuild Database on Reboot”. Check it and click on “yes”.
