Wanted to confirm there is no way around the the following before I move the rule to RM.
Want an outlet to be turned on when temperature is above a "high setpoint" ONLY within a specific time window, and then want that outlet turned off when temp drops below a "low setpoint" OR at the end of the specific time window.... which ever comes first.
Using Simple Rules I see that once turned on, if the Restriction time window ends before the "low setpoint" is reached then the outlet STAYS ON. That is to say, the rule is "parked" and no longer able to act on "Turn off when temperature is less than ".
I understand this is a logical consequence of the Restrictions, I'm just double checking function before I move this rule out of Simple Automation, even tho it seems to be a simple rule.
Thanks.
