Show more.. link for the Past Logs is broken
@gopher.ny
Hub is C8Pro, platform is 2.5.2.139
Option "Show more..." for the past logs use to be working just fine but now it is broken, i.e. clicking on this links does absolutely nothing. I did not use this option for a long time. So, I have no idea since when it became broken.
UPDATE:
The same goes for the C7 on the same platform.
I wasn't able to replicate, but I am running the latest beta version. So either it is fixed or the problem doesn't exist.
Two hubs on a latest release (C7 annd C8) exhibit this problem. So, the problem definitely exists but hopefully already fixed.
Are you sure that app has more events? Try without any filters.
Yes, this specific rule is a reminder. It fires 4 times a day and definitely has more events. For the test I tried few different rules without filters and tried this on C7. Clicking on this link doesn't do anything on both hubs but in a past (didn't try this for a long time) it definitely worked.
Out of curiosity, since I don't normally go that far back, what is the max length of the PAST logs?
C5 on 2.5.2.139 and the "more" is working correctly in past logs for me. I was able to scroll through all of the pages to the very end.
One file for about 1MB.
I'm on 2.4.4.156 so theres that BUT - the problem occurs for me when I have a filter set - either a specific device(s) or a search criteria. it will only show the found items on the page that was there before the search was applied.
If you hit the 'more button ' over and over and over until you have a really long log, then apply your search is the only way past I'm aware of.
We have cleaned up when the Show More appears (or doesn't) in the next update (currently in beta).
@bobbyD Any chance of allowing a larger size (optionally or by default) for the logs?
Especially on the C8 Pro, there should be more than enough space for a 10MB or even 100MB file.
Mine shows about 1GB free space in the file manager.
That would certainly allow more logging for busier systems.
Thanks!
I have found that how much you log on your hubs can limit how far back "Show more" can show.
