I have virtual switch that I toggle for when my dog is outside. I have the notification app send me a notification every 15 min that the switch is on(sometimes we forget when it's about to rain). However, I don't see an option to displayed the elapsed time it's been on. Is there a way to display the elapsed time the device has been on in the notifications app?
If not, I guess, I could create a rule with notifications, but assume that would use more hub resources.
Thanks so much for pointing me in the right direction. I was able to successfully create my rule to calculate my time. I accomplished this by using a hub variable with a connector switch as the trigger(Aqara zigbee button toggles on and off) and another variable as the elapsed time tally. I added some variable math to calculate the elapsed time in minutes; all are repeating actions that run every minute. I have a separate rule for the notification, which referenced the hub variable for the elapsed time.
One gotcha is that since my trigger is also involved in my conditions, I found my the hub was immediately bypassing one of the conditions, even when false(the hub processed too quickly for the situation). I mitigated this by creating a 3 second delay to start. Also, I found the hub was always rounding down to the closest minute so I added a minute to satisfy my OCD.
Below is a screenshot of the rule. If there's a more efficient/better way to do this, I'm all ears. I'm about 4 months into this so I'm still learning.
