I received 4 new Shelly WiFi Plus US Plugs, I went through the device setup and added the IP address for the system driver. I could not get the driver to talk to the device. I had other shelly devices and the driver usually creates a 0 and 1 channel on the dual devices, yet this one will not setup a channel 0.
I can manage the shelly via web page. This seems to be an issue R2.3.2.134
I think I might be having the same issue. Previous when adding a Plug or shelly switch it would create a Parent and then Child device. Now it does not seem as if the Child device is being created. I even tried to add a previous device that was currently working (had both Parent and Child) and this is doing the same thing. Just the Parent device is created and the Child device (Generic Metering Device) is missing.
Hopefully I am doing something wrong...but I suspect there might have been a change?
