Anybody knows whether the Shelly WIFI 0-10V Dimmer can be used in Hubitat? I can't seem to get them to work (I have the full ShellyUSA package installed).
The dimming works fine when using the web interface to the shelly device directly.
FWIW.. I did try the Zooz 54 0-10v dimmer but the one I have is either defective or not compatible with the 0-10V constant current (24v) power supply I have for my LED lights. (again..Works fine with a Shelly)
Yep that did it! I had the drivers installed but had not selected the Shelly Plus/Pro xPM. Then created the child device and boom! Working..
FWIW... My lowest dimming setting does NOT kill the lights completely so I need to get the power switched. That's not a problem of Shelly but of the power supply.
I have configured those in the Shelly device itself. That seems to work but 0% on the Shelly still shows a faint glow regardless the set points. Probably a power supply issue. I need to see if open or short on the 10V really switches it off.
