Shelly uni - how do I run 2 Shelly uni devices on one hubitat?
I have 2 shelly uni devices, one of them is working good... however I have another one that I would like to use on the same hubitat but I cant figure out what to do because it has its own ip address ..
any help would be great
Which driver are you using?
Regardless, you likely just need to create a second virtual device for the second Uni. It should be the same process you used to add the first one.
omg I forgot about the virtual device thing, just did that and all is good :slight_smile: Thank you
Download the Hubitat app
