Shelly Pro 3 driver
I have been searching the forum but haven’t found anything on the Shelly pro 3, I do apologize ahead of time if there has been.
I am working on changing up the control of my heated floors and driveway. Previous control is having reliability issues. I love the idea of a wired Ethernet relay option. I have a ton of wireless items and not one hasn’t run into some issue as some point.
So I’m asking is there a driver for the Shelly pro 3? If there is please share and provide any assistance possible to quickly integrate.
If there are other ideas for a good wired relay solution I would be open. I know there are some out there but tougher integration.
I do have a few zooz zen16 multi relay, but I like the idea on the Shelly that I could have some secondary protections like time limits built in to shut off if for some reason connection is lost with Hubitat. But I already have sensors tied to hubitat and virtual thermostats setup for multiple rooms that I can tie the floor control into.
I will greatly appreciate all the help. With having a family now I don’t have nearly the amount of time to study, tinker and troubleshoot like I did 5 years ago. Have to result to more then key solutions in some situations now.
Hello,
Check this thread
This thread contains Wi-Fi/Ethernet Shelly device drivers.
It has driver that should be able to handle any Gen2+ device (including plus, pro, mini).
It you'll have any questions you may ask them there.
