Bruno,
I'm in Belgium. The reason I put HE in between is offline usage.
Hubitat will keep working when the internet connection is down.
Straight from google it needs the internet connection.
that's the main benefit.
And dashboards offcourse!
Bruno,
Of course, I am aware HE stays locale, but when you want to use a voice assistant there has to be a internet link between the Shelly device and the voice assistant (Google or Alexa), the question is, why put HE between it? The only benefit I see is you can deconnect the Shelly cloud, but then you put HE between it and if the hub goes down...
True,
Google commands will be unavailable. there's no offline support for google.
About the hub going down, that's an issue, as is every "Single point of failure". I have a second one that I can have up and running in 30 minutes.
The advantages are:
Offline availability and therefor:
Smart switches will still work
All your automation (which is the core reason of having a HE in the first place) will still work.
If you don't use switches, set up dashboards and you'll still be able to turn your lights on and off using PC, Smartphone or tablet.
The only thing you really lose is the Google integration/voice commands.
In my case, I use it for heating/cooling, lights, Security, and a LOT of automation.
What is your setup for heating?
I have 7 Daikin Heatpumps. I use the "Daikin WiFi Split System Hubitat" driver to connect them.
I use the built in "Thermostat Controller" app to control heating times on schedule in winter (spring, autumn too).
I use "Xiaomi contact sensors" on doors and windows and "Weather Station" to measure outside temperatures. When heating, it turns off when a window opens or is open and the outside temp is lower than the target temp. When Cooling, it turns off when the outside temp is higher and the window opens or is open. The doors do the same, but with a 1 minute delay.
I use the google community app to propagate these to google home so I can give voice commands to heat/cool/set temperature etc. Home hubs can be used to set the heatpumps via the touchscreen. Dashboards to easily control the Heating from the computer, Smartphone or Tablet.
When I got the heatpumps they said I could control them via the app or IFTTT.
Well, that's where the hub and its community shine. Fully automated now.
Got electrical heating for the bathroom. Handled by a "Shelly 1" and the HE automation.
I love google home and voice commands, but it is not going to cripple me when my connection goes down
Hello, I am not also using the SHELLYUSA driver, but you make reference to the native driver. I am completely new to Hubitat. Where is this native driver? I do not see it anywhere in my hubitat.
The System Hubitat Driver:
Go to "devices", add a new Virtual device and choose the System driver of your device type
The Community Driver;
thanks. I am not sure how I missed that. I suppose I did not recheck after the recent Hubitat upgrade.
In the latest release Release 2.2.4 Available there is reference to Shelly 1PM using "Shelly WiFi Switch"
Where can we get this Driver please ?
thank you
It would be the "Shelly WiFi Switch" driver that is built into the Hub's firmware.
Many thanks. I applied the Shelly WiFi Switch driver and now have no control over the Shelly1 units.
I have rebooted the devices and can still operate them using the SHelly app but no control using HE. I will shortly upload the logs in case it reveals anything useful.
Even though the Driver has been changed the data below still shows the old driver is in use - I changed the driver at 13:30
In the Log App 2 is Hubitat@Dashboard it says
app:22020-12-02 17:57:16.647 errorjava.lang.IllegalArgumentException: Command 'on' is not supported by device. on line 592 (dashboardCmd)
Change the driver to "device" then hit clear state and clear schedules. Then change the driver back and save. Whenever you're changing your driver should always clear this stuff out just in case.
Thank you Boris, where is clear state and clear schedules ?
Once you change the device driver to "device" and click save you will see them.
Thank you Sir, your time and knowledge is appreciated very much. I will let you know.
Updated, I still have the same issue
app:22020-12-02 18:24:34.940 errorjava.lang.IllegalArgumentException: Command 'on' is not supported by device. on line 592 (dashboardCmd)
Does On/OFF work direct in the device?
are you sure you have chosen the correct device in your dasboard tile?
Hello, I am new to all this. I recently bought the Shelly Door/Window2 and not realizing the ShellyUSA Drivers require an mqtt which makes my wishful solution no good. But then I came across this thread. May I ask, do you have the driver version without requiring mqtt you discussed above available?
That device has to use MQTT with Hubitat since the hub does not support CoAP..... OR you can use marker API and use the action urls to accomplish what you want.
Thank you Bruno. The UNderfloor Heating Circuits have worked in the past. I now need to revisit pairing that Shelly1 once more after trying to remove an inactive "Parent" app it removed the child app.
I have two underfloor circuits in this kitchen, one shows a Parent child which I removed by accident, the other does not have the child which does not show the on off switch option and is using the System "Shelly WiFi Switch"
I have the same with another Shelly1 where I can turn it on using the Device panel but not from the Dashboard panel. The Shelly app remains OK through out
I think you are mixing up the 2 available drivers
