Short answer is that Shelly Motion sensors can call/visit a link when motion is triggered. Hubitat Rule Machine can have a visit to a link as a trigger.
Below are all the steps I follow to make this happen. It includes a few unnecessary but good overall steps
How to Setup a Shelly Motion Sensor
Find the Sensor with Shelly app
Find the Sensor in Router, rename (Sensor Motion X ) and set Static IP
Connect Motion Sensor to Hubitat
Create a Virtual Motion Sensor in Hubitat to correspond to this device
Has anyone managed to get one of the new Shelly Plus 1PM relays working? Just tried to use the Shelly Wifi Switch driver like I did for a previous Shelly 1PM (non Plus) and it wouldn't find the device when I entered the IP address.
I did noticed that the Shelly Plus is saying that its using channel 0 where as the non plus relay is using channel 1. Not sure if thats relevant.
Anyone else had any luck with these? thanks
An update here. I found the limitation of doing this with Local End Points.
What I tried to:
Trigger a Motion Sense Event with Local End Points (Works like a charm)
Add Close lights in 5 minutes if no further Motion is Detected (The challenging part)
Shelly has a Motion Blind Time (lowest 1 minute). This means that If any motion is detected in that 1 minute:
No motion event is sent to Hubitat
The timer is Reset back to 60 minutes
So in the scenario I am trying to build, if there is uninterrupted motion for 5 minutes, a signal is never sent to Hubitat and lights switch off.
Potential Workarounds
Do a End of Motion Detected event, and connect it to a different Local End Point. I think this also needs an extra step (i.e. action close lights, or turn this sensor to Y). This solution will probably work but it's Messy
I will look again into using the Shelly Drivers instead of the Local End Points as that is probably a more straightforward way to do it.
This (with some tweaking if needed) will most probably work - but I think it falls in the Messy solution category (I have 15+ Shelly Motion Sensors and 12 Konnected ones)
Newish here. I have successfully installed four Shelly 2.5 modules to control mains powered Somfy shades, sincere thanks to Scott Grayban and Allterco for providing the Hubitat integration. Basic functions and scheduling are working great.
I'm able to create Dashboard tiles for the shades but their status icon is only shown as "On", the various other statuses from the driver code windowShade.value like: closed, closing, open, opening, partially open, don't come through. Yes I'm using the "Shade" dashboard template.
I’m having an issue and looking for some help.
I am using a Shelly Plus 1 with the 4 PM driver.
I can toggle the light on and off through hubitat but it does not report back that the switch is on or off. If I manually poll or refresh it will update.
Its most likely that this driver doesnt manage synchro with device correctly. However there is one workaround for this. Use maker api and add refresh url of HE coresponding device to shelly device (in 1PM its called webhooks) for ON and OFF command. This way, everytime shelly change its status, HE will refresh it status.
