Hey! Has anyone bought (or received) the new Shelly motion sensor? I'm really interested in buying a few, but it is important to me that i can integrate them into HE.
I just received a Shelly Uni. I have it setup to monitor my Sump pump backup battery voltage. Is there any way to display the ADC value on a Hubitat dashboard tile? It is currently set to a static ip with no cloud connection enabled.
There is a driver in this thread (not mine)
You can do basic integration over http + virtual decice, untill driver will be ready.
Just got my UNI in today, will be a couple weeks before I have anything ready for a Official Shelly driver.
Oh and got the Shelly Motion as well so I'll get to both drivers soon.
So I have a kinda working driver for the Shelly Motion... bear in mind that the Shelly Motion IS NOT SUITABLE as a security device due to the limits on the motion settings. Mainly because of this setting "Blind time in minutes (from 1 to 1440) after last detected motion." If you want to try it out let me know in the comments. I won't release it unless people here approve of the driver.
Please read this facebook post/comment for more info.
Did you happen to create a button1 DH?
I see there was mention of it last Aug.
Maybe I am blind and not seeing it on your github
Hi tomw,
I would be interested in an Shelly i3 driver. Follwoing your post from Aug '20 I think you were working on something like that. Would you make this avialble?
Kind regards
I am having issues connecting my Shelly Duo's to hubitat. I am using a wifi mesh (tenda) does this matter? anyone point me to a step by step ( i followed the instructions i could find but to no avail)
thanks
@bcopeland Hi Brian.
Any idea's why I can't connect my Shelly Duo's using "shelly wifi CT bulbs"? I have put the IP address for the bulb from the Shelly app but can't connect.
Thanks in advance
Chris
Hi Scott
Is there a URL for where I can get 3.0.8 please
- Copyright : © 2020 Allterco Robotics US
- cloud : true
- has_update : false
- Version : 3.0.6
- DriverStatus : New Version Available (Version: 3.0.8)
- UpdateInfo :
- Fixed missing directive for EM3 meters - cloudConnected : true
- rssi : -77
- author : Scott Grayban
Please see the very FIRST post of this thread...
Thank you Sir
Is There support for The new add-on feature which enables a Reed switch instead of temperatur sensors?
Nope
Damn, guess i'll just throw it in the bin then, really needed That feedback trigger, since the app, cannot control how the add-on switch is triggering i need it to be on for 1 second and of again, but it does not work with the timerfunction in the shelly app
Driver code is open source which I have mentioned a million times here. No one is stopping you from adding that support. I simply don't have the time to maintain the code these days.
fair enough, i have added support for the ext_switch_state as attribute, and as ContactSensor (open/closed) there is even a setting for if you have "reversed the contact sensor as this can be done in the shelly app"
I recommend that you use the ContactSensor with MakerAPI, that way you can create a HTTP call in the shelly relay to update the state of the sensor in hubitat on-the-fly like a normal ContactSensor would
* Shelly Switch Relay Driver
* Copyright © 2018-2019 Scott Grayban
* Copyright © 2020 Allterco Robotics US
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Hubitat is the Trademark and intellectual Property of Hubitat Inc.
* Shelly is the Trademark and Intellectual Property of Allterco Robotics Ltd
* See all the Shelly Products at https://shelly.cloud/
* Supported devices are:
* 1/1PM/2/2.5/EM/Plug/PlugS/4Pro/EM3/SHPLG-U1
* Changes:
* Dion Pedersen: Added ContactSensor function for external swith module, note must use black and yellow wire, selection of reversed as in native shelly-app
* To get instant response from the Shelly Contact Sensor, go to the shelly App, and setup a HTTP call for MakerAPI, otherwise there is a need for manual refresh
* 3.0.8 - Fixed missing directive for EM3 meters
* 3.0.7 - Added external temperature and humidity attributes.
* - ctraf settings removed from EM3
* 3.0.6 - Added VoltageMeasurement for the 4Pro input voltage
* - Fixed a issue where the ntp server and devicename would be deleted if the relay # was not 0
* 3.0.5 - Added support for the Shelly Plug US
* 3.0.4 - Added support for External Sensor Hat for the Shelly1 and 1PM
* 3.0.3 - Added support for the ShellEM 3 phase
* 3.0.2 - Fixed a bug with Shelly EM/4PRO to not set a relayname for the second EM channel
* - Fixed excessive logging chatter
* - Added NTP server preference
* - Added manual/poll for refreshing
* 3.0.1 - Added switch to prevent(protect) accidental power off or on. Simular to the phone app pin code.
* - Added Mains or Battery for power source for the Shelly 1 and 2.5
* - Fixed the secure login username password (!!Note: Passwords must not contain these special characters &?)
* - Added code that will update Maxpower setting if changed via app or embedded webserver
* - Prevent any settings from being set, shown or retrieved until IP is set
* - Only show correct device settings *after* IP is saved since all settings do not apply to all shelly devices
* - More code for Plug and PlugS support
* - Added missing code to turn off JSON debugging after set time
* - You can now set the device name and relay channel name. EG; DeviceName can be a location/room and RelayName can be light, appliance or a power strip controler
* - Many thanks to Dawid Filo for his help in debuging the Plug(S) code
* 3.0.0 - Fixed some bug regarding the getDataValue which would prevent the driver from working correctly
* 2.0.9 - Added the ability to update device FW
* 2.0.8 - RSSI value is definded as exelent, good or poor. The actual rssi reading is under state variables.
* 2.0.7 - Added MaxPower to attributes
* - Added preference setting for max_power for relay channel
* - Removed getShellyAddress()
* - Added ctraf setting for Shelly EM Current transformer type
* - Changed powerTotal to energy attribute to match the capability "EnergyMeter"
* - Removed importURL
* - Code located at https://gitlab.borgnet.us:8443/sgrayban/shelly-drivers/tree/master/Drivers/Shelly
* 2.0.6 - Added new tC/tF attributes
* - Added deviceType for device identification for current/future code
* - ShellyEM support
* - Added new capability VoltageMeasurement
* - ShellyPlug support
* 2.0.5 - Code added for JSON debug switch
* - New attributes that can be used in RM
* - 1 call for API status now
* - Supports all relay channels 0-3
* - Supports username/password
* - Added the ability to reboot device
* 2.0.4 - Code added for all Shelly relay switches
* 2.0.3 - Changed operand for refresh rate in update()
* 2.0.2 - Changed how the update check worked if refresh rate was set to No Selection
* 2.0.1 - Modified code to allow install more then once - added version control
* 2.0.0 - Removed more ST code and added auto refresh option and debugging info switches.
* 1.0.0 - Initial port
import groovy.json.*
import groovy.transform.Field
def setVersion(){
state.Version = "3.0.8"
state.InternalName = "ShellyAsASwitch"
metadata {
definition (
name: "Shelly Switch Relay",
namespace: "ShellyUSA",
author: "Scott Grayban",
importUrl: "https://raw.githubusercontent.com/ShellyUSA/Hubitat-Drivers/master/Shelly-as-a-Switch.groovy"
capability "Actuator"
capability "Sensor"
capability "ContactSensor"
capability "Refresh"
capability "Switch"
capability "RelaySwitch"
capability "Polling"
capability "PowerMeter"
capability "VoltageMeasurement"
capability "SignalStrength"
capability "PowerSource"
capability "TemperatureMeasurement"
capability "RelativeHumidityMeasurement"
attribute "FW_Update_Needed", "string"
attribute "LastRefresh", "string"
attribute "power", "number"
attribute "overpower", "string"
attribute "internal_tempC", "number"
attribute "internal_tempF", "number"
attribute "DeviceOverTemp", "string"
attribute "MAC", "string"
attribute "RelayChannel", "number"
attribute "Primary_IP", "string"
attribute "Primary_SSID", "string"
attribute "Secondary_IP", "string"
attribute "Secondary_SSID", "string"
attribute "WiFiSignal", "string"
attribute "Cloud", "string"
attribute "Cloud_Connected", "string"
attribute "energy", "number"
attribute "DeviceType", "string"
attribute "eMeter", "number"
attribute "reactive", "number"
attribute "MaxPower", "number"
attribute "CircuitAmp", "string"
attribute "LED_Output", "string"
attribute "LED_NetworkStatus", "string"
attribute "DeviceName", "string"
attribute "RelayName", "string"
attribute "NTPServer", "string"
attribute "ext2_temperature", "number"
attribute "ext2_humidity", "number"
attribute "ext3_temperature", "number"
attribute "ext3_humidity", "number"
attribute "ext_switch_state", "number"
command "RebootDevice"
command "UpdateDeviceFW" // ota?update=1
//command "updatecheck" // Only used for development
command "getSettings"
preferences {
def refreshRate = [:]
refreshRate << ["1 min" : "Refresh every minute"]
refreshRate << ["5 min" : "Refresh every 5 minutes"]
refreshRate << ["15 min" : "Refresh every 15 minutes"]
refreshRate << ["30 min" : "Refresh every 30 minutes"]
refreshRate << ["manual" : "Manually or Polling Only"]
input("ip", "string", title:"IP", description:"Shelly IP Address", defaultValue:"" , required: true)
input name: "username", type: "text", title: "Username:", description: "(blank if none)", required: false
input name: "password", type: "password", title: "Password:", description: "(blank if none)", required: false
if (ip == null) input("channel", "number", title:"Relay Channel", description:"0,1,2,or 3 :", defaultValue:"0" , required: true) // Show at device setup only
if (ip != null) { // show settings *after* IP is set as some settings do not apply to all devices
if (getDataValue("model") in ["SHEM","SHEM-3"]) channel = 0 // The EM devices only have 1 relay
if (channel < 1) input name: "ntp_server", type: "text", title: "NTP time server:", description: "E.G. time.google.com or 192.168.0.59", defaultValue: "time.google.com", required: true
// Only show for channel 0 since the device name is for the entire device
if (channel < 1) input name: "devicename", type: "text", title: "Give your device a name:", description: "EG; Location/Room<br>NO SPACES in name", required: false
if (!(getDataValue("model") in ["SHPLG-S","SHPLG-1","SHEM","SHEM-3","SHPLG-U1"])) { // The Plug devices do not offer a relay name
input name: "relayname", type: "text", title: "Label your relay control:", description: "EG; Light/Appliance<br>NO SPACES in name", required: false
if (channel != 1 && getDataValue("model") in ["SHEM","SHEM-3"])
input "protect", "enum", title:"Prevent accidental off/on", defaultValue: true, options: [Yes:"Yes",No:"No"], required: true
if (!(getDataValue("model") in ["SHDM-1","SHSW-PM","SHSW-1","SHEM","SHEM-3"])) {
if (getDataValue("model") in ["SHEM","SHEM-3"]) {
input("eMeter", "number", title:"eMeter Channel", description:"0, 1 or 2 :", defaultValue:"0" , required: true)
if (getDataValue("model") == "SHEM") {
input("ctraf", "number", title:"Current Amperage(ctraf)", description:"50 or 120:", defaultValue:"50" , required: true)
if (getDataValue("model") in ["SHSW-25","SHSW-1"]) {
input("powersource", "enum", title:"Mains/Battery", description:"Shelly Power Source", defaultValue: true, options: [mains:"Mains",battery:"Battery"], required: true)
if (getDataValue("model") in ["SHSW-1","SHSW-PM"]) {
input name: "external_sensors", type: "bool", title: "Use External Sensor?", defaultValue: false
input "external_contact_reversed", "enum", title:"Is the external contact sensor reversed?", defaultValue: false, options: [Yes:"Yes",No:"No"], required: true
if (getDataValue("model") in ["SHPLG-S","SHPLG-1","SHPLG-U1"]) {
input("led_status", "enum", title:"LED indication for network status", description:"Enable/Disable", defaultValue: false, options: [false:"Enable",true:"Disable"])
input("led_power", "enum", title:"LED indication for output status", description:"Enable/Disable", defaultValue: false, options: [false:"Enable",true:"Disable"])
input("maxpower", "number", title:"Max Power", description:"Max power allowed for this relay is 2500W", defaultValue:"2500" , required: true)
state.RelayName = "N/A"
sendEvent(name: "RelayName", value: state.RelayName)
updateDataValue("RelayName", state.RelayName)
if (!(getDataValue("model") in ["SHSW-1","SHEM","SHDM-1","SHPLG-S","SHPLG-1","SHPLG-U1"])) {
input("maxpower", "number", title:"Max Power", description:"Max power allowed for this relay is 2300W", defaultValue:"2300" , required: true)
if (!(getDataValue("model") in ["SHEM","SHEM-3"]))
input("refresh_Rate", "enum", title: "Device Refresh Rate", description:"<font color=red>!!WARNING!!</font><br>DO NOT USE if you have over 50 Shelly devices.", options: refreshRate, defaultValue: "manual")
if (getDataValue("model") in ["SHEM","SHEM-3"]) input("refresh_Rate", "enum", title: "Device Refresh Rate", options: refreshRate, defaultValue: "1 min")
input "locale", "enum", title: "Choose refresh date format", required: true, defaultValue: true, options: [US:"US MM/DD/YYYY",UK:"UK DD/MM/YYYY"]
} // END IP check
input name: "debugOutput", type: "bool", title: "Enable debug logging?", defaultValue: true
input name: "debugParse", type: "bool", title: "Enable JSON parse logging?", defaultValue: true
input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
input name: "Shellyinfo", type: "text", title: "<center><font color=blue>Info Box</font><br>Shelly API docs are located</center>",
description: "<center><br><a href='http://shelly-api-docs.shelly.cloud/' title='shelly-api-docs.shelly.cloud' target='_blank'>[here]</a></center>"
def initialize() {
log.info "initialize"
if (txtEnable) log.info "initialize"
def installed() {
log.debug "Installed"
state.DeviceName = "NotSet"
state.RelayName = "NotSet"
def uninstalled() {
unschedule()
log.debug "Uninstalled"
def updated() {
if (txtEnable) log.info "Preferences updated..."
log.warn "Debug logging is: ${debugOutput == true}"
log.warn "Switch protection is: ${settings?.protect}"
unschedule()
dbCleanUp()
if (ip != null) { // Don't set until IP is saved
if (!(getDataValue("model") in ["SHSW-1","SHEM"])) {
sendSwitchCommand "/settings/relay/${channel}?max_power=${maxpower}"
if (getDataValue("model") in ["SHPLG-1","SHPLG-S","SHPLG-U1"]) {
logDebug "LED setting ${led_status} and ${led_power}"
sendSwitchCommand "/settings?led_status_disable=${led_status}"
sendSwitchCommand "/settings?led_power_disable=${led_power}"
if (channel < 1) sendSwitchCommand "/settings?sntp_server=${ntp_server}"
// Set device and relay name
if (channel < 1) sendSwitchCommand "/settings?name=${devicename}"
if (!(getDataValue("model") in ["SHPLG-S","SHPLG-1","SHPLG-U1"])) sendSwitchCommand "/settings/relay/${channel}?name=${relayname}"
if (getDataValue("model") == "SHEM") sendSwitchCommand "/settings/relay/${channel}?ctraf_type=${ctraf_type}"
switch(refresh_Rate) {
case "1 min" :
runEvery1Minute(autorefresh)
break
case "5 min" :
runEvery5Minutes(autorefresh)
break
case "15 min" :
runEvery15Minutes(autorefresh)
break
case "30 min" :
runEvery30Minutes(autorefresh)
break
case "manual" :
unschedule(autorefresh)
log.info "Autorefresh disabled"
break
if (txtEnable) log.info ("Auto Refresh set for every ${refresh_Rate} minute(s).")
if (debugOutput) runIn(1800,logsOff) //Off in 30 minutes
if (debugParse) runIn(300,logsOff) //Off in 5 minutes
state.LastRefresh = new Date().format("YYYY/MM/dd \n HH:mm:ss", location.timeZone)
version()
refresh()
getSettings()
private dbCleanUp() {
state.remove("version")
state.remove("Version")
state.remove("ShellyfwUpdate")
state.remove("power")
state.remove("overpower")
state.remove("dcpower")
state.remove("max_power")
state.remove("internal_tempC")
state.remove("Status")
state.remove("RelayName")
def refresh(){
logDebug "Shelly Status called"
getSettings()
def params = [uri: "http://${username}:${password}@${ip}/status"]
try {
httpGet(params) {
resp -> resp.headers.each {
logJSON "Response: ${it.name} : ${it.value}"
obs = resp.data
logJSON "params: ${params}"
logJSON "response contentType: ${resp.contentType}"
logJSON "response data: ${resp.data}"
state.powerSource = settings?.powersource
sendEvent(name: "powerSource", value: state.powerSource)
state.RelayChannel = channel
sendEvent(name: "RelayChannel", value: state.RelayChannel)
if (obs.temperature != null) sendEvent(name: "internal_tempC", value: obs.temperature)
if (obs.tmp != null) {
sendEvent(name: "internal_tempC", unit: "C", value: obs.tmp.tC)
sendEvent(name: "internal_tempF", unit: "F", value: obs.tmp.tF)
if (obs.overtemperature != null) sendEvent(name: "DeviceOverTemp", value: obs.overtemperature)
if (obs.wifi_sta != null) {
state.rssi = obs.wifi_sta.rssi
state.ssid = obs.wifi_sta.ssid
state.ip = obs.wifi_sta.ip
sendEvent(name: "Primary_SSID", value: state.ssid)
sendEvent(name: "Primary_IP", value: state.ip)
-30 dBm Excellent | -67 dBm Good | -70 dBm Poor | -80 dBm Weak | -90 dBm Dead
signal = state.rssi
if (signal <= 0 && signal >= -70) {
sendEvent(name: "WiFiSignal", value: "<font color='green'>Excellent</font>", isStateChange: true);
} else
if (signal < -70 && signal >= -80) {
sendEvent(name: "WiFiSignal", value: "<font color='green'>Good</font>", isStateChange: true);
} else
if (signal < -80 && signal >= -90) {
sendEvent(name: "WiFiSignal", value: "<font color='yellow'>Poor</font>", isStateChange: true);
} else
if (signal < -90 && signal >= -100) {
sendEvent(name: "WiFiSignal", value: "<font color='red'>Weak</font>", isStateChange: true);
state.mac = obs.mac
sendEvent(name: "MAC", value: state.mac)
sendEvent(name: "rssi", value: state.rssi)
// Shelly EM emeters
if (state.DeviceType == "SHEM" || state.DeviceType == "SHEM-3") {
if (eMeter == 0 )sendEvent(name: "power", value: obs.emeters.power[0])
if (eMeter == 0 )sendEvent(name: "voltage", value: obs.emeters.voltage[0])
if (eMeter == 0 )sendEvent(name: "reactive", value: obs.emeters.reactive[0])
if (eMeter == 0 )sendEvent(name: "energy", value: obs.emeters.total[0])
if (eMeter == 1 )sendEvent(name: "power", value: obs.emeters.power[1])
if (eMeter == 1 )sendEvent(name: "voltage", value: obs.emeters.voltage[1])
if (eMeter == 1 )sendEvent(name: "reactive", value: obs.emeters.reactive[1])
if (eMeter == 1 )sendEvent(name: "energy", value: obs.emeters.total[1])
if (state.DeviceType == "SHEM-3") {
if (eMeter == 2 )sendEvent(name: "power", value: obs.emeters.power[2])
if (eMeter == 2 )sendEvent(name: "voltage", value: obs.emeters.voltage[2])
if (eMeter == 2 )sendEvent(name: "reactive", value: obs.emeters.reactive[2])
if (eMeter == 2 )sendEvent(name: "energy", value: obs.emeters.total[2])
state.eMeter = eMeter
sendEvent(name: "eMeter", value: state.eMeter)
// Device FW Updates
state.has_update = obs.has_update
if (state.has_update == true) {
if (txtEnable) log.info "sendEvent NEW SHELLY FIRMWARE"
sendEvent(name: "FW_Update_Needed", value: "<font color='red'>FIRMWARE Update Required</font>")
if (state.has_update == false) {
if (txtEnable) log.info "sendEvent Device FW is current"
sendEvent(name: "FW_Update_Needed", value: "<font color='green'>Device FW is current</font>")
// Cloud
state.cloud = obs.cloud.enabled
if (state.cloud == true) {
sendEvent(name: "Cloud", value: "<font color='green'>Enabled</font>")
} else {
sendEvent(name: "Cloud", value: "<font color='red'>Disabled</font>")
state.cloudConnected = obs.cloud.connected
if (state.cloudConnected == true) {
sendEvent(name: "Cloud_Connected", value: "<font color='green'>Connected</font>")
} else {
sendEvent(name: "Cloud_Connected", value: "<font color='red'>Not Connected</font>")
// Relays
if (obs.relays != null) {
if (channel ==0) ison = obs.relays.ison[0]
if (channel ==1) ison = obs.relays.ison[1]
if (channel ==2) ison = obs.relays.ison[2]
if (channel ==3) ison = obs.relays.ison[3]
if (ison == true) {
sendEvent(name: "switch", value: "on")
} else {
sendEvent(name: "switch", value: "off")
// Power Meters
if (obs.meters != null) {
if (channel ==0) power = obs.meters.power[0]
if (channel ==1) power = obs.meters.power[1]
if (channel ==2) power = obs.meters.power[2]
if (channel ==3) power = obs.meters.power[3]
if (power != null) sendEvent(name: "power", unit: "W", value: power)
// Power Totals
if (channel ==0) powerTotal = obs.meters.total[0]
if (channel ==1) powerTotal = obs.meters.total[1]
if (channel ==2) powerTotal = obs.meters.total[2]
if (channel ==3) powerTotal = obs.meters.total[3]
if (powerTotal != null) sendEvent(name: "energy", unit: "W", value: powerTotal)
// Over Power
if (channel ==0) overpower = obs.relays.overpower[0]
if (channel ==1) overpower = obs.relays.overpower[1]
if (channel ==2) overpower = obs.relays.overpower[2]
if (channel ==3) overpower = obs.relays.overpower[3]
if (overpower != null) sendEvent(name: "overpower", value: overpower)
// These devices don't offer the
// battery or mains option
// so the default is set to mains
state.powerSource = "mains"
sendEvent(name: "powerSource", value: "mains")
if (getDataValue("model") == "SHSW-44") {
sendEvent(name: "voltage", value: obs.voltage)
if (getDataValue("model") == "SHSW-PM") {
if (getDataValue("model") == "SHSW-21") {
if (getDataValue("model") == "SHPLG-1") {
if (getDataValue("model") == "SHPLG-S") {
if (getDataValue("model") == "SHPLG-U1") {
// Externel Sensors Shelly 1 and 1PM only
if (external_sensors) {
if (obs.ext_sensors != null) {
t_unit = obs.ext_sensors.temperature_unit
state.temperature_unit = t_unit
ext_switch = obs.ext_switch
if (obs.ext_switch['0'] != null) {
sendEvent(name: "ext_switch_state", value:obs.ext_switch['0'].input)
if (external_contact_reversed == "No")
if (obs.ext_switch['0'].input == 0)
sendEvent(name:"contact", value: "open", isStateChange: false, descriptionText: "Contact was Opened")
if (obs.ext_switch['0'].input == 1)
sendEvent(name:"contact", value: "closed", isStateChange: false, descriptionText: "Contact was Closed")
if (external_contact_reversed == "Yes")
if (obs.ext_temperature['0'] != null) sendEvent(name: "temperature", unit: t_unit, value: obs.ext_temperature['0']."t${t_unit}")
if (obs.ext_humidity['0'] != null) sendEvent(name: "humidity", value: obs.ext_humidity['0'].hum)
if (obs.ext_temperature['1'] != null) sendEvent(name: "ext2_temperature", unit: t_unit, value: obs.ext_temperature['1']."t${t_unit}")
if (obs.ext_humidity['1'] != null) sendEvent(name: "ext2_humidity", value: obs.ext_humidity['1'].hum)
if (obs.ext_temperature['2'] != null) sendEvent(name: "ext3_temperature", unit: t_unit, value: obs.ext_temperature['2']."t${t_unit}")
if (obs.ext_humidity['2'] != null) sendEvent(name: "ext3_humidity", value: obs.ext_humidity['2'].hum)
} // End try
} catch (e) {
log.error "something went wrong: $e"
} // End if !==ip
} // End Refresh Status
// Get shelly device type
def getSettings(){
logDebug "Get Shelly Settings"
def paramsSettings = [uri: "http://${username}:${password}@${ip}/settings"]
try {
httpGet(paramsSettings) {
respSettings -> respSettings.headers.each {
logJSON "ResponseSettings: ${it.name} : ${it.value}"
obsSettings = respSettings.data
logJSON "params: ${paramsSettings}"
logJSON "response contentType: ${respSettings.contentType}"
logJSON "response data: ${respSettings.data}"
state.DeviceType = obsSettings.device.type
if (state.DeviceType == "SHSW-1") sendEvent(name: "DeviceType", value: "Shelly 1")
if (state.DeviceType == "SHSW-PM") sendEvent(name: "DeviceType", value: "Shelly 1PM")
if (state.DeviceType == "SHSW-21") sendEvent(name: "DeviceType", value: "Shelly 2")
if (state.DeviceType == "SHSW-25") sendEvent(name: "DeviceType", value: "Shelly 2.5")
if (state.DeviceType == "SHSW-44") sendEvent(name: "DeviceType", value: "Shelly 4Pro")
if (state.DeviceType == "SHEM") sendEvent(name: "DeviceType", value: "Shelly EM")
if (state.DeviceType == "SHEM-3") sendEvent(name: "DeviceType", value: "Shelly EM3")
if (state.DeviceType == "SHPLG-1") sendEvent(name: "DeviceType", value: "Shelly Plug")
if (state.DeviceType == "SHPLG-S") sendEvent(name: "DeviceType", value: "Shelly PlugS")
if (state.DeviceType == "SHPLG-U1") sendEvent(name: "DeviceType", value: "Shelly Plug US")
state.ShellyHostname = obsSettings.device.hostname
state.sntp_server = obsSettings.sntp.server
sendEvent(name: "NTPServer", value: state.sntp_server)
// Plug and PlugS have network and output LED indicator lights
if (obsSettings.led_status_disable != null) {
if (obsSettings.led_status_disable == false) {
sendEvent(name: "LED_NetworkStatus", value: "<font color='green'>Enabled</font>")
} else {
sendEvent(name: "LED_NetworkStatus", value: "<font color='red'>Disabled</font>")
if (obsSettings.led_power_disable == false) {
sendEvent(name: "LED_Output", value: "<font color='green'>Enabled</font>")
} else {
sendEvent(name: "LED_Output", value: "<font color='red'>Disabled</font>")
//Get Device name
if (obsSettings.name != "NotSet") {
state.DeviceName = obsSettings.name
sendEvent(name: "DeviceName", value: state.DeviceName)
updateDataValue("DeviceName", state.DeviceName)
if (txtEnable) log.info "DeviceName is ${obsSettings.name}"
} else if (obsSettings.name != null) {
//Get Relay name
if (getDataValue("model") != "SHPLG-S" && getDataValue("model") != "SHPLG-1" && getDataValue("model") != "SHPLG-U1" && getDataValue("model") != "SHEM") {
if (obsSettings.relays != null) {
if (channel == 0) relay_name = obsSettings.relays.name[0]
if (channel == 1) relay_name = obsSettings.relays.name[1]
if (channel == 2) relay_name = obsSettings.relays.name[2]
if (channel == 3) relay_name = obsSettings.relays.name[3]
if (relay_name != null) {
state.RelayName = relay_name
if (txtEnable) log.info "RelayName is ${relay_name}"
} else {
} // The Plug devices do not offer a relay name
state.RelayName = obsSettings.relays.name[0]
if (obsSettings.wifi_sta1 != null) {
state.rssi = obsSettings.wifi_sta1.rssi
state.Secondary_ssid = obsSettings.wifi_sta1.ssid
state.Secondary_IP = obsSettings.wifi_sta1.ip
if (obsSettings.wifi_sta1.enabled == true) sendEvent(name: "Secondary_SSID", value: state.Secondary_ssid)
if (state.Secondary_IP != null) sendEvent(name: "Secondary_IP", value: state.Secondary_IP)
// Max watt setting
if (obsSettings.relays.max_power != null) {
if (channel ==0) max_power = obsSettings.relays.max_power[0]
if (channel ==1) max_power = obsSettings.relays.max_power[1]
if (channel ==2) max_power = obsSettings.relays.max_power[2]
if (channel ==3) max_power = obsSettings.relays.max_power[3]
if (max_power == null) max_power = 0
if (txtEnable) log.info "Max power is set to ${max_power} Watts"
sendEvent(name: "MaxPower", unit: "W", value: max_power)
state.max_power = max_power
device.updateSetting("maxpower",[value: max_power, type:"number"])
// Circuit Amperage Setting ShellyEM ONLY
if (channel ==0) ctraf_type = obsSettings.emeters.ctraf_type[0]
if (channel ==1) ctraf_type = obsSettings.emeters.ctraf_type[1]
if (txtEnable) log.info "Circuit Amperage is set to ${ctraf} Amps"
sendEvent(name: "CircuitAmp", unit: "amp" , value: "${ctraf}")
state.ctraf_type = ctraf_type
logDebug "updating data values"
updateDataValue("model", state.DeviceType)
updateDataValue("ShellyHostname", state.ShellyHostname)
updateDataValue("ShellyIP", state.ip)
updateDataValue("ShellySSID", obsSettings.wifi_sta.ssid)
updateDataValue("manufacturer", "Allterco Robotics")
updateDataValue("MAC", state.mac)
} // End try
} catch (e) {
} // End if !==ip
//switch.on
def on() {
if (protect == "No") {
logDebug "Executing switch.on"
sendSwitchCommand "/relay/${channel}?turn=on"
if (protect == "Yes") {
sendEvent(name: "switch", value: "<font color='red'>LOCKED</font>")
runIn(1, refresh)
//switch.off
def off() {
logDebug "Executing switch.off"
sendSwitchCommand "/relay/${channel}?turn=off"
runIn(1, refresh)
def ping() {
logDebug "ping"
poll()
def logsOff(){
log.warn "debug logging auto disabled..."
device.updateSetting("debugOutput",[value:"false",type:"bool"])
device.updateSetting("debugParse",[value:"false",type:"bool"])
def autorefresh() {
if (locale == "UK") {
logDebug "Get last UK Date DD/MM/YYYY"
state.LastRefresh = new Date().format("d/MM/YYYY \n HH:mm:ss", location.timeZone)
sendEvent(name: "LastRefresh", value: state.LastRefresh, descriptionText: "Last refresh performed")
if (locale == "US") {
logDebug "Get last US Date MM/DD/YYYY"
state.LastRefresh = new Date().format("MM/d/YYYY \n HH:mm:ss", location.timeZone)
if (txtEnable) log.info "Executing 'auto refresh'" //RK
refresh()
private logJSON(msg) {
if (settings?.debugParse || settings?.debugParse == null) {
log.info "$msg"
private logDebug(msg) {
if (settings?.debugOutput || settings?.debugOutput == null) {
log.debug "$msg"
// handle commands
//RK Updated to include last refreshed
def poll() {
if (txtEnable) log.info "Executing 'poll'" //RK
refresh()
def sendSwitchCommand(action) {
if (txtEnable) log.info "Calling ${action}"
def params = [uri: "http://${username}:${password}@${ip}/${action}"]
try {
httpPost(params) {
logDebug "Response: ${it.name} : ${it.value}"
} // End try
} catch (e) {
runIn(2, refresh)
def RebootDevice() {
if (txtEnable) log.info "Rebooting Device"
def params = [uri: "http://${username}:${password}@${ip}/reboot"]
try {
httpPost(params) {
} // End try
} catch (e) {
runIn(15,refresh)
def UpdateDeviceFW() {
if (txtEnable) log.info "Updating Device FW"
def params = [uri: "http://${username}:${password}@${ip}/ota?update=1"]
try {
httpPost(params) {
} // End try
} catch (e) {
runIn(30,refresh)
// Check Version ***** with great thanks and acknowlegment to Cobra (github CobraVmax) for his original code **************
def version(){
updatecheck()
schedule("0 0 18 1/1 * ? *", updatecheck) // Cron schedule
// schedule("0 0/1 * 1/1 * ? *", updatecheck) // Test Cron schedule
def updatecheck(){
setVersion()
def paramsUD = [uri: "https://raw.githubusercontent.com/ShellyUSA/Hubitat-Drivers/master/resources/version.json", contentType: "application/json; charset=utf-8"]
try {
httpGet(paramsUD) { respUD ->
if (debugParse) log.debug " Version Checking - Response Data: ${respUD.data}"
def copyrightRead = (respUD.data.copyright)
state.Copyright = copyrightRead
def newVerRaw = (respUD.data.versions.Driver.(state.InternalName))
def newVer = (respUD.data.versions.Driver.(state.InternalName).replace(".", ""))
def currentVer = state.Version.replace(".", "")
state.UpdateInfo = (respUD.data.versions.UpdateInfo.Driver.(state.InternalName))
state.author = (respUD.data.author)
state.icon = (respUD.data.icon)
if(newVer == "NLS"){
state.DriverStatus = "<b>** This driver is no longer supported by $state.author **</b>"
log.warn "** This driver is no longer supported by $state.author **"
} else
if(newVer == "BETA"){
state.Status = "<b>** THIS IS BETA CODE **</b>"
log.warn "** BETA CODE **"
} else
if(currentVer < newVer){
state.DriverStatus = "<b>New Version Available (Version: $newVerRaw)</b>"
log.warn "** There is a newer version of this driver available (Version: $newVerRaw) **"
log.warn "** $state.UpdateInfo **"
} else
if(currentVer > newVer){
state.DriverStatus = "<b>You are using a Test version of this Driver (Version: $state.Version)</b>"
} else {
state.DriverStatus = "Current"
log.info "You are using the current version of this driver"
} // httpGet
} // try
catch (e) {
log.error "Something went wrong: CHECK THE JSON FILE AND IT'S URI - $e"
if(state.DriverStatus == "Current"){
state.UpdateInfo = "Up to date"
sendEvent(name: "DriverUpdate", value: state.UpdateInfo)
sendEvent(name: "DriverStatus", value: state.DriverStatus)
} else {
sendEvent(name: "DriverAuthor", value: "sgrayban")
sendEvent(name: "DriverVersion", value: state.Version)
You might want to host this on GitHub, or use the preformated text option before posting it. It's the little button that looks like </>. Select all the text you want as preformated and then click that button.
I don't know if @Evilborg has the time, but if he does, you might also consider sending him a pull request on GitHub.
