Any info on a Shelly 4pm driver? No code in the file (first post) some alternative?
first gen or 2nd gen ?
If you have Pro 4PM it is expected to work (either using the topic main repo driver or the one I posted). It has 4 'input' components and 4 'switch' componets. Though I have no unit to test on.
The topic main repo driver will need to be installed 4 times (4 instances) setting up each instance to each corresponding channel.
The one I posted will require only a single instance. For Pro 4PM it should spawn 4 'input' child devices and 4 'switch' child devices after setting IP and pressing 'Configure'.
It's Shelly Pro 4 PM.
Shelly Pro 4 PM | Shelly Technical Documentation
It is V2 (gen2) protocol device.
This driver https://raw.githubusercontent.com/ShellyUSA/Hubitat-Drivers/master/PLUS/ShellyPlus.groovy
The Driver is for Shelly 3EM 3Phase power meter? If so can't seem to get it to work. It connects to the device bot no power metering options.... any ideas?
This driver currently has no Pro 3 EM support.
It you could send me driver logs, I could try to add.
I can try to add using official documentation. Log will help to check events/notifications with real device behavior.
Enable description logging to see extensive device logs. If will start to dump all device responses.
Also, driver should show detected components list in the device data section down below. Would be helpfull to see that list.
P.S.:
To be clear
Shelly 3EM and Shelly Pro 3EM are two different devices of different protocol generations. There is no way to add the first one except writing a completely new driver. While the second one can be added.
Kk I'll set everything up and provide the data
I updated driver with Pro 3 EM code in the repo. But I cannot test it. So I assume by default that there are issues
Driver should spawn 4 child devices: Phase A, Phase B, Phase C and Total. For now I did not exposed aparent power and returned energy readings. Also neutral wire current value is not exposed.
To properly spawn child devices:
0. Enable debug logging to see all the request and responses in the device log
- Set IP and save settings
- Press 'Configure'.
'Configure' clears all previous child devices, polls device for all the componets and their instance counts, spawns child devices according to the fetched info, opens web socket connection and sends status request over it to start getting device notifications.
Ideally there should be no errors
If by chance everything will work as you expect, you may disable debug logging.
Ok I removed the device and added it anew. I dont think it connects properly
I get an error importing the driver code
Logs
You picked only a single file. Driver uses libraries and custom generic component devices (due to the lack of needed capabilities in the builtin generic driver set).
You either need to install libraries listed at the driver code top, or simply take the whole bundle (as a single operation). Taking bundle is simpler: go to the bundle tab on the left; there will be import button that will ask you for a ZIP file. ZIP-file contains all the dependencies inside.
Bundle can be downloaded from repo and uploaded. Or it can be uploaded directly from repo URL copying link from
If you want to install driver manually, then you will need 4 child device drivers and 3 library files.
Ok connected to the device,
No child devices present. We have readings. Im still waiting for my solar plant so the sensors aren't attached... but that's no problem I believe... no child devices
2023-04-28 23:13:13.961info(null) Meter generic report: Electric:voltage - 234.2V
dev:322023-04-28 23:13:13.960info(null) Meter generic report: Electric:voltage - 0.1V
dev:322023-04-28 23:13:13.958info(null) Meter generic report: Electric:voltage - 0.1V
dev:322023-04-28 23:13:13.957info(null) Phase C power factor 1.00
dev:322023-04-28 23:13:13.955info(null) Phase B power factor 1.00
dev:322023-04-28 23:13:13.954info(null) Phase A power factor 1.00
dev:322023-04-28 23:13:13.952info(null) Meter generic report: Electric:amperage - 0.082A
dev:322023-04-28 23:13:13.951info(null) Meter generic report: Electric:amperage - 0.027A
dev:322023-04-28 23:13:13.949info(null) Meter generic report: Electric:amperage - 0.027A
dev:322023-04-28 23:13:13.948info(null) Meter generic report: Electric:amperage - 0.028A
dev:322023-04-28 23:13:13.946info(null) Meter generic report: Electric:power - -0.135W
dev:322023-04-28 23:13:13.945info(null) Meter generic report: Electric:power - -0.1W
dev:322023-04-28 23:13:13.943info(null) Meter generic report: Electric:power - 0.0W
dev:322023-04-28 23:13:13.942info(null) Meter generic report: Electric:power - 0.0W
dev:322023-04-28 23:13:13.939info(null) parseShellyEnergyMeterStatus [a_act_power:0.0, b_aprt_power:0.0, b_act_power:0.0, total_current:0.082, n_current:null, total_act_power:-0.135, a_voltage:0.1, c_current:0.027, b_current:0.027, a_current:0.028, b_voltage:0.1, a_aprt_power:0.0, c_voltage:234.2, a_pf:1.00, c_aprt_power:6.2, total_aprt_power:6.241, id:0, c_pf:1.00, b_pf:1.00, c_act_power:-0.1]
dev:322023-04-28 23:13:10.959info(null) Meter generic report: Electric:voltage - 234.2V
dev:322023-04-28 23:13:10.957info(null) Meter generic report: Electric:voltage - 0.1V
dev:322023-04-28 23:13:10.956info(null) Meter generic report: Electric:voltage - 0.1V
dev:322023-04-28 23:13:10.954info(null) Phase C power factor 1.00
dev:322023-04-28 23:13:10.953info(null) Phase B power factor 1.00
dev:322023-04-28 23:13:10.951info(null) Phase A power factor 1.00
dev:322023-04-28 23:13:10.950info(null) Meter generic report: Electric:amperage - 0.083A
dev:322023-04-28 23:13:10.948info(null) Meter generic report: Electric:amperage - 0.028A
dev:322023-04-28 23:13:10.947info(null) Meter generic report: Electric:amperage - 0.027A
dev:322023-04-28 23:13:10.945info(null) Meter generic report: Electric:amperage - 0.028A
dev:322023-04-28 23:13:10.944info(null) Meter generic report: Electric:power - -0.05W
dev:322023-04-28 23:13:10.942info(null) Meter generic report: Electric:power - 0.0W
dev:322023-04-28 23:13:10.941info(null) Meter generic report: Electric:power - 0.0W
dev:322023-04-28 23:13:10.939info(null) Meter generic report: Electric:power - 0.0W
dev:322023-04-28 23:13:10.937info(null) parseShellyEnergyMeterStatus [a_act_power:0.0, b_aprt_power:0.0, b_act_power:0.0, total_current:0.083, n_current:null, total_act_power:-0.050, a_voltage:0.1, c_current:0.028, b_current:0.027, a_current:0.028, b_voltage:0.1, a_aprt_power:0.0, c_voltage:234.2, a_pf:1.00, c_aprt_power:6.5, total_aprt_power:6.477, id:0, c_pf:1.00, b_pf:1.00, c_act_power:0.0]
I will investigate tomorrow.
Good news is that WS stream is live. Device sends reports as expected. Component names turned to be correct. The issue is strictly in missing child devices (to which to put these readings).
Would be helpfull to see log of "Configue" operation (when button is pressed). There could be some usefull error.
And component list from the bottom of the driver (to see how exactly EM and EMData components were detected)
No problem everything You need to get this going.
Logs spat few errors
dev:322023-04-29 08:04:35.135info(null) parseShellyEnergyMeterStatus [a_act_power:0.0, b_aprt_power:0.0, b_act_power:0.0, total_current:0.081, n_current:null, total_act_power:-0.185, a_voltage:0.1, c_current:0.027, b_current:0.027, a_current:0.028, b_voltage:0.1, a_aprt_power:0.0, c_voltage:234.5, a_pf:1.00, c_aprt_power:6.3, total_aprt_power:6.258, id:0, c_pf:1.00, b_pf:1.00, c_act_power:-0.2]
dev:322023-04-29 08:04:34.464infoDevice updates [:]
dev:322023-04-29 08:04:33.206errorCan't get device status for null: Bad Request
dev:322023-04-29 08:04:33.195infoparseShellyCloudStatus [connected:true]
dev:322023-04-29 08:04:33.192errorjava.lang.NullPointerException: Cannot get property 'value' on null object on line 895 (method parse)
dev:322023-04-29 08:04:33.170infoparseShellyCloudStatus [connected:true]
dev:322023-04-29 08:04:33.122errorjava.lang.NullPointerException: Cannot get property 'value' on null object on line 890 (method parse)
dev:322023-04-29 08:04:33.050errorjava.lang.NullPointerException: Cannot get property 'value' on null object on line 895 (method parse)
dev:322023-04-29 08:04:33.038errorjava.lang.NullPointerException: Cannot get property 'value' on null object on line 890 (method parse)
dev:322023-04-29 08:04:32.980infoWS query: {"params":{id:0}, "id":40, "method":"EMData.GetStatus", "src":"hub"}
dev:322023-04-29 08:04:32.958infoWS query: {"params":{id:0}, "id":30, "method":"EM.GetStatus", "src":"hub"}
dev:322023-04-29 08:04:32.940infoHTTP query: Wifi.GetStatus([:])
dev:322023-04-29 08:04:32.925infoHTTP query: Shelly.CheckForUpdate([:])
dev:322023-04-29 08:04:32.909infoHTTP query: Cloud.GetStatus([:])
dev:322023-04-29 08:04:32.869infoWS query: {"params":{id:0}, "id":40, "method":"EMData.GetStatus", "src":"hub"}
dev:322023-04-29 08:04:32.859infoWS query: {"params":{id:0}, "id":30, "method":"EM.GetStatus", "src":"hub"}
dev:322023-04-29 08:04:32.851infoHTTP query: Wifi.GetStatus([:])
dev:322023-04-29 08:04:32.847infoHTTP query: Shelly.CheckForUpdate([:])
dev:322023-04-29 08:04:32.841infoHTTP query: Cloud.GetStatus([:])
dev:322023-04-29 08:04:32.828errorconfigure: No signature of method: user_driver_drozovyk_Shelly_Plus_Pro_xPM_591.getMeterDevice() is applicable for argument types: (java.lang.Short) values: [1]
Possible solutions: getMeterDevices(java.lang.Short), getCoverDevice(java.lang.Short), getInputDevice(java.lang.Short), getMeterDeviceName(java.lang.Short, int), getSwitchDevice(java.lang.Short). Can't configure child devices. Please, re-try.
Device details
I updated the driver with fixes. Just reimport the bundle (no need to reinstall device itself)
Configured device should look now somethin like this
Thanks to your logs I was able to emulate device notifications locally. Also I added powerFactor attribute to the child defices.
Readings that are currently not supplied to any attribute are 'aparent power' and ' returned energy'. Also per-channel error are not reported. These can be added later taking into account desired use case scenario.
Also atm there were no notifications regarding energy (as according to the device documentation such notification should arrive when device stores accumulated energy readings in the internal memory).
I suspect this might be caused by the device notification frequency. Should be configurable on the device itself (notification interval and notification threshold.. something like that)
No. Not in the driver but on the device itself.
