Changed ISP's and reconstructed my LAN. Now, I can't get this driver to work again. Can someone (re)post the initialization sequence? TIA!
@teronl just install the latest driver version above and reboot your hub and it should settle down.
Yessir! Thanks. It did settle down after a couple of reboots.
Did you ever get the logging to shut off? I can't. They keep turning back on. Thanks.
I edited the driver to turn the logging off.
Thanks, mate. Ya know, right after I sent you the message, I got bold and did the same. It worked!
@cybrmage just updated to Hubitat Release 2.2.0.132 and am getting a startup failed error. @teronl are you seeing this too?
Summary
dev:10252020-05-24 01:39:41.490 pm errororg.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: General error during canonicalization: Importing [java.util.concurrent.TimeUnit] is not allowed java.lang.SecurityException: Importing [java.util.concurrent.TimeUnit] is not allowed at com.hubitat.hub.executor.SecureASTCustomizerHub.assertImportIsAllowed(SecureASTCustomizerHub.java:623) at com.hubitat.hub.executor.SecureASTCustomizerHub.access$200(SecureASTCustomizerHub.java:125) at com.hubitat.hub.executor.SecureASTCustomizerHub$SecuringClassVisitor.visitField(SecureASTCustomizerHub.java:686) at org.codehaus.groovy.ast.ClassNode.visitContents(ClassNode.java:1068) at com.hubitat.hub.executor.SecureASTCustomizerHub.call(SecureASTCustomizerHub.java:565) at org.codehaus.groovy.control.CompilationUnit.applyToPrimaryClassNodes(CompilationUnit.java:1065) at org.codehaus.groovy.control.CompilationUnit.doPhaseOperation(CompilationUnit.java:603) at org.codehaus.groovy.control.CompilationUnit.processPhaseOperations(CompilationUnit.java:581) at org.codehaus.groovy.control.CompilationUnit.compile(CompilationUnit.java:558) at groovy.lang.GroovyClassLoader.doParseClass(GroovyClassLoader.java:298) at groovy.lang.GroovyClassLoader.parseClass(GroovyClassLoader.java:268) at groovy.lang.GroovyClassLoader$parseClass$1.call(Unknown Source) at com.hubitat.hub.executor.ExecutorHelper.parseDevClass(ExecutorHelper.groovy:284) at sun.reflect.GeneratedMethodAccessor1093.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite$PogoCachedMethodSiteNoUnwrapNoCoerce.invoke(PogoMetaMethodSite.java:210) at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite.callCurrent(PogoMetaMethodSite.java:59) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:174) at com.hubitat.hub.executor.ExecutorHelper.loadDriverClass(ExecutorHelper.groovy:331) at com.hubitat.hub.executor.ExecutorHelper.getCachedDeviceClass(ExecutorHelper.groovy:311) at sun.reflect.GeneratedMethodAccessor545.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite$PogoCachedMethodSiteNoUnwrapNoCoerce.invoke(PogoMetaMethodSite.java:210) at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite.callCurrent(PogoMetaMethodSite.java:59) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:166) at com.hubitat.hub.executor.ExecutorHelper.getDeviceExecutorScript(ExecutorHelper.groovy:268) at com.hubitat.hub.executor.ExecutorHelper$getDeviceExecutorScript$0.call(Unknown Source) at com.hubitat.handler.BaseDeviceHandler.getDeviceExecutor(BaseDeviceHandler.groovy:392) at sun.reflect.GeneratedMethodAccessor558.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite$PogoCachedMethodSiteNoUnwrapNoCoerce.invoke(PogoMetaMethodSite.java:210) at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite.callCurrent(PogoMetaMethodSite.java:59) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:166) at com.hubitat.handler.BaseDeviceHandler.runDeviceMethodPrivate(BaseDeviceHandler.groovy:185) at sun.reflect.GeneratedMethodAccessor557.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite$PogoCachedMethodSiteNoUnwrapNoCoerce.invoke(PogoMetaMethodSite.java:210) at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite.callCurrent(PogoMetaMethodSite.java:59) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:174) at com.hubitat.handler.BaseDeviceHandler.runDeviceMethod(BaseDeviceHandler.groovy:137) at com.hubitat.handler.BaseDeviceHandler$runDeviceMethod.call(Unknown Source) at com.hubitat.hub.job.GenericJob.execute(GenericJob.groovy:56) at org.quartz.core.JobRunShell.run(JobRunShell.java:202) at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) 1 error (getDeviceState)
I'm getting the same.
@bravenel looking at past topics this General error during canonicalization error has appeared before after Hubitat software updates. I waited to updated a couple weeks and just did to the latest 2.2.0.152 but it might have occurred on one of the updates before that. Is this due to a security update? I this something that needs to be fixed on the Sharp Driver side or Hubitat firmware side?
I'm running .131 and it no longer works. I do not have logging turned on right now. So, I can't see what the error is.
I'm pretty sure 131 is the version that broke it, because I use the driver quite a bit now that we're on the patio a lot.
I went into the Sharp Driver Groovy and hit save and got this message.
What does this mean in retrospect to the recent Hubitat Updates that seem to have broke the driver?
Looks like it doesn't like [java.util.concurrent.TimeUnit] in line 13. Does this need to be modified and to what?
Looks like a pretty harmless class... just returning the current time or something. My programming skills are super rusty. So, hopefully, @bravenel or someone like that will jump in and rescue us.
Anyone have any update, would really like to get my tv working again. Was this a security hole that was plugged?
@cybrmage just checking to see if you had any thoughts on what it would take to fix the [java.util.concurrent.TimeUnit] issue we are experiencing. Thanks.
@cybrmage @Angus_M @teronl @Gnant @teronl @bravenel
Love to have this working again, or at least some clues as to what it would take to fix the java.util.concurrent.TimeUnit error.
Clearly, this thread doesn't meet the standard for response. It was fun while it lasted.
this should be fixed in 2.2.1
IT's FIXED!. Thank you so much @chuck.schwer the latest update fixed the issue with this driver.
