Could you please add a Shade position condition check in the Rule machine. I'd like to be able to know if a shade is open or closed or what position it is in for a rule.
If your shades have a "Dimmer" value you can already do this in RM:
I don't own/use any shades so not sure if reporting a dimmer level is common w/those devices.
Doesn't work for me. I'm using Denny Page's driver which, unlike Justin Walker's, allows me to specify a specific position instead of just Open, "My Position", and closed. Trying to treat it as a dimmer returns null in a condition.
Assuming that the driver gives you an attribute back for the position you may want to check to see if it is available under the custom actions.
Yes it is! Thanks for the help.
