I have had my C7 for a few months now and I keep getting a warning about severe hub load. Not sure what is causing this. I do not have a ton of devices or apps and pretty simple rules.
Do you see any errors in your log?
I wonder if it might be related to a corrupted databaseโฆ If that was the cause, saving a backup locally, doing a soft reset on the hub from http://hubitat.local:8081/ and then restoring the backup would fix that issue.
Weather app would be my guess.
No, I do not see any errors. I looked through the logs and best I can tell nothing is seems wrong, but I am really green with this.
Whenever I had the severe hub alerts it was due to running out of memory. Try setting your event history and state history to 5 and 5 and see it the alert stops happening. You can set this for all devices at once from the logs page under the device tab.
Thanks, I will give it a shot
A reboot should free up the memory also as least temporarily while you figure out what is causing it.
Did a soft reset and knock on wood no warning yet 24hrs later. Thanks for the advice.
